I Installed Ubuntu on raspberry pi and installed remote Desktop by the following command
apt-get install xrdp
but it Does not work whenever i try to connect it shows a black screen and turns off would anyone help ? thanks in advance
i installed ubuntu server from here :
from here ubuntu-18.04.3-desktop-amd64
More Details about the Pi i am running :
processor       : 0
BogoMIPS        : 38.40
Features        : fp asimd evtstrm crc32 cpuid
CPU implementer : 0x41
CPU architecture: 8
CPU variant     : 0x0
CPU part        : 0xd03
CPU revision    : 4
processor       : 1
BogoMIPS        : 38.40
CPU architecture: 8
CPU variant     : 0x0
CPU part        : 0xd03
CPU revision    : 4
processor       : 2
BogoMIPS        : 38.40
CPU architecture: 8
CPU variant     : 0x0
CPU part        : 0xd03
CPU revision    : 4
processor       : 3
BogoMIPS        : 38.40
CPU architecture: 8
CPU variant     : 0x0
CPU part        : 0xd03
CPU revision    : 4
Hardware        : BCM2835
Revision        : a02082
Serial          : 000000009c800ff0
Model           : Raspberry Pi 3 Model B Rev 1.2
done it from the below links:
here and here
If you are trying to use remote desktop on Ubuntu or Xubuntu 18.04 you may find that after logging in all you see is a blank screen.
One cause of this is that xfce4 has added code that prevents a second session from opening. You will find that if your computer's main screen is logged into xfce4 you may not be able to use it with xrdp.
To solve this "second session" problem and allow as many sessions as you need, edit /etc/xrdp/startwm.sh and add these lines before the lines that test and execute Xsession. The $HOME/.profile is not part of the solution, but is something that should be run before starting the session anyway.
unset DBUS_SESSION_BUS_ADDRESS
unset XDG_RUNTIME_DIR
. $HOME/.profile
karel
  • 122,292
  • 133
  • 301
  • 332
