I have 3 partitions in Ubuntu and I am trying to install Anaconda, that is pretty big, but my hard disk is 500GB. I receive an error saying that there is no space in my drive. I explored partitions and it seems the biggest partition /dev/sda3 is not mounted or anyway it seems is not used (not appearing in df).
  • How can I start to use /dev/sda3 and continuing to work in my home directory?
  • Could you please clarify my partition situation?
  • Where all my application have been installed until now?
Thank you.
xxxx@xxxx-home:/$ sudo parted -l
Model: ATA Hitachi HTS54757 (scsi)
Disk /dev/sda: 750GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number  Start   End     Size    File system  Name  Flags
 1      1049kB  538MB   537MB   fat32              boot, esp
 2      538MB   1612MB  1074MB  ext4
 3      1612MB  750GB   749GB
Model: Linux device-mapper (linear) (dm)
Disk /dev/mapper/ubuntu--vg-ubuntu--lv: 4295MB
Partition Table: loop
Disk Flags:
Number  Start  End     Size    File system  Flags
 1      0.00B  4295MB  4295MB  ext4
xxxx@xxxx-home:/$ lsblk
NAME                      MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
loop0                       7:0    0  89.1M  1 loop /snap/core/8213
loop1                       7:1    0  89.1M  1 loop /snap/core/8268
sda                         8:0    0 698.7G  0 disk
├─sda1                      8:1    0   512M  0 part /boot/efi
├─sda2                      8:2    0     1G  0 part /boot
└─sda3                      8:3    0 697.1G  0 part
  └─ubuntu--vg-ubuntu--lv 253:0    0     4G  0 lvm  /
sr0                        11:0    1  1024M  0 rom
xxxx@xxxxx-home:/$ df -i
Filesystem                         Inodes  IUsed   IFree IUse% Mounted on
udev                              2030747    535 2030212    1% /dev
tmpfs                             2038604    855 2037749    1% /run
/dev/mapper/ubuntu--vg-ubuntu--lv  262144 137988  124156   53% /
tmpfs                             2038604      1 2038603    1% /dev/shm
tmpfs                             2038604      3 2038601    1% /run/lock
tmpfs                             2038604     18 2038586    1% /sys/fs/cgroup
/dev/loop1                          12842  12842       0  100% /snap/core/8268
/dev/loop0                          12842  12842       0  100% /snap/core/8213
/dev/sda2                           65536    299   65237    1% /boot
/dev/sda1                               0      0       0     - /boot/efi
tmpfs                             2038604     11 2038593    1% /run/user/1000
I believe you did not add sda3 to the volume group. So you'd need to:
Extend your volume group to include sda3 ("ubuntu--vg" is the volume group):
vgextend ubuntu--vg /dev/sda3
Check the new size of your volume group:
vgs
Extend your logical volume to the entire volume group space ("ubuntu--lv" is the logical volume):
lvextend -l 100%FREE /dev/ubuntu--vg/ubuntu--lv
Check the new size of your logical volume:
lvs
