my problem is ''cp'' command I can't understand why I can't copy a simple text file for example: I have on the desktop two files "fis1" and "fis2" and in "fis1" I have "perfect" (text file) and I want to copy the "perfect" file to "fis2" [which is still on the desktop] and any attempt with "cp" does not work
first of all let's clarify something: fis1 and fis2 are folders and not files? If yes, you must first find out where you are located (in wich directory) if you are using the terminal. The command is: pwd
if, like me you are located in the home directory (which ends with this sign ~$ ) then you have to relocate in the Desktop directory. You do this by writing command: cd Desktop
After that you can use this command to copy the file: cp fis1/perfect fis2/
I hope I helped you.
