Whenever I insert an external USB storage device in my USB port on my new Slimbbok pro x15 running Kubuntu 18.04 I get:
An error occurred while accessing '1,9 GiB Removable Media', the system responded: The requested operation has failed: Error mounting system-managed device /dev/sdb1: unknown filesystem type 'swap'
The devices work fine on my thinkpad x240 (Kubuntu 19.10). I have tested with a USB stick and an external HDD.
Any ideas?
My /etc/fstab (I am not sure this is relevant)
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
/dev/mapper/kubuntu--vg-root / ext4 errors=remount-ro 0 1
# /boot was on /dev/sda2 during installation
UUID=1727d751-47db-4665-9ae5-2c2c8970c2ca /boot ext4 defaults 0 2
# /boot/efi was on /dev/sda1 during installation
UUID=7F24-5C01 /boot/efi vfat umask=0077 0 1
/dev/mapper/kubuntu--vg-swap_1 none swap sw 0 0
/dev/sdb1 none ext4 defaults 0 0
Shall I remove the last line?
