As the title says, I did do-release-upgrade today and have problem now. I've got this computer duel-booted with a win10 disk, and now the Kubuntu 19.10 install is unbootable. The disk has FDE, and even though I've mounted and decrypted my Ubuntu disk, boot-repair is not able to fix it, throwing the error Please use this software in a live-session (live-CD or live-USB). This will enable this feature.
This is the output for fdisk -l:
Disk /dev/loop0: 1.68 GiB, 1791954944 bytes, 3499912 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/sda: 931.53 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: ST1000DM003-1CH1
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 90AA474C-403B-48D8-A51F-EA67103A29E9
Device Start End Sectors Size Type
/dev/sda1 2048 1023999 1021952 499M Windows recovery environment
/dev/sda2 1024000 1228799 204800 100M EFI System
/dev/sda3 1228800 1261567 32768 16M Microsoft reserved
/dev/sda4 1261568 1953523711 1952262144 930.9G Microsoft basic data
Disk /dev/sdb: 1.84 TiB, 2000398934016 bytes, 3907029168 sectors
Disk model: ST2000DM006-2DM1
Disklabel type: dos
Disk identifier: 0xab30ec36
Device Boot Start End Sectors Size Id Type
/dev/sdb1 * 2048 1499135 1497088 731M 83 Linux
/dev/sdb2 1501182 3907028991 3905527810 1.8T 5 Extended
/dev/sdb5 1501184 3907028991 3905527808 1.8T 83 Linux
Partition 2 does not start on physical sector boundary.
Disk /dev/sdc: 28.96 GiB, 31071404032 bytes, 60686336 sectors
Disk model: USB 3.0 FD
Disklabel type: dos
Disk identifier: 0x48e7426f
/dev/sdc1 * 2048 60686335 60684288 29G c W95 FAT32 (LBA)
Disk /dev/mapper/luks-d5504240-d15c-4453-8767-9beb20b9d785: 1.84 TiB, 1999628140544 bytes, 3905523712 sectors
Disk /dev/mapper/kubuntu--vg-root: 1.84 TiB, 1998602633216 bytes, 3903520768 sectors
Disk /dev/mapper/kubuntu--vg-swap_1: 976 MiB, 1023410176 bytes, 1998848 sectors
I attempted to run boot-repair once before decrypting it, and that broke it even further. Prior to the first attempt, I got the usual grub-rescue men, however now no OS is detected at all (despite all of my files being there, as I can confirm through the live-usb). I'm not really sure what to do now. I'd really rather not reinstall, if possible.
edit: Here is the boot report from boot-repair: https://paste.ubuntu.com/p/KSyx5WQtTv/
It seems that if I'm able to open this disk in my live session, it should be possible to fix the problem, since I'm able to see the /boot directory in sdb.
