I have changed my macbook pro operating system to Ubuntu Linux last night. That night the wifi network was recognized but this morning it does not recognizing wifi network at all . Please help. here is what I got running Terminal:
ebmo@ebmo-MacBookPro:~$ nmcli
enp1s0f0: unavailable
"Broadcom Limited NetXtreme BCM57765 Gigabit Ethernet PCIe"
ethernet (tg3), 40:6C:8F:52:D5:50, hw, mtu 1500
lo: unmanaged
"lo"
loopback (unknown), 00:00:00:00:00:00, sw, mtu 65536
Use "nmcli device show" to get complete information about known devices and
"nmcli connection show" to get an overview on active connection profiles.
Consult nmcli(1) and nmcli-examples(5) manual pages for complete usage details.
ebmo@ebmo-MacBookPro:~$ nmcli connection show
NAME UUID TYPE DEVICE
ENNN 2ee7e18c-80cf-4ea5-8eff-df6343119437 wifi --
HUAWEI P20 Pro d39ea4a1-6a84-4bc2-9693-17b4eed1dc5d wifi --
Wired connection 1 f61c19a7-d0f2-3270-886b-7673319531df ethernet --
ebmo@ebmo-MacBookPro:~$ lshw-c network
lshw-c: command not found
ebmo@ebmo-MacBookPro:~$ lshw -c
Hardware Lister (lshw) - B.02.18
usage: lshw [-format] [-options ...]
lshw -version
-version print program version (B.02.18)
format can be
-html output hardware tree as HTML
-xml output hardware tree as XML
-json output hardware tree as a JSON object
-short output hardware paths
-businfo output bus information
options can be
-class CLASS only show a certain class of hardware
-C CLASS same as '-class CLASS'
-c CLASS same as '-class CLASS'
-disable TEST disable a test (like pci, isapnp, cpuid, etc. )
-enable TEST enable a test (like pci, isapnp, cpuid, etc. )
-quiet don't display status
-sanitize sanitize output (remove sensitive information like serial numbers, etc.)
-numeric output numeric IDs (for PCI, USB, etc.)
-notime exclude volatile attributes (timestamps) from output
ebmo@ebmo-MacBookPro:~$ lshw -c network
WARNING: you should run this program as super-user.
*-network
description: Ethernet interface
product: NetXtreme BCM57765 Gigabit Ethernet PCIe
vendor: Broadcom Inc. and subsidiaries
physical id: 0
bus info: pci@0000:01:00.0
logical name: enp1s0f0
version: 10
serial: 40:6c:8f:52:d5:50
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=tg3 driverversion=3.137 firmware=57765-v1.37 latency=0 link=no multicast=yes port=twisted pair
resources: irq:16 memory:a0400000-a040ffff memory:a0410000-a041ffff
*-network UNCLAIMED
description: Network controller
product: BCM4331 802.11a/b/g/n
physical id: 0
bus info: pci@0000:02:00.0
version: 02
width: 64 bits
clock: 33MHz
configuration: latency=0
resources: memory:a0600000-a0603fff
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
ebmo@ebmo-MacBookPro:~$ rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
