I am using ubuntu on text only with terminal in portrait mode to run the GTK application. I have removed GUI/Desktop mode. I tried to run it on ubuntu and other Linux operating systems.
I used 'startx' and 'xinit' without using x server.
The application is able to run, but it is running in landscape view only while I am using ubuntu in text mode with portrait view.
I tried the following commands,
$ xinit ./(gtk application)
I also tried to embed 'xinit' with 'xrandr -o left ' as below,
$ xinit && xrandr -o left ./(gtk application)
but above is also not making the application run in the portrait mode.
However when I tried the 'xinit' command alone, then a temporary xserver white window of xinit opens up in the landscape view, where I was able to run and rotate the application in portrait view using 'xrandr -o left' command followed by application running as below mentioned,
In the text mode console
$ xinit
In the 'xinit' white console
$ xrandr -o left
$ ./(gtk_application)
But I want to make application run and rotate into portrait view using a single line command on text mode console only, with or without writing any script.
I tried to make a script with the above commands and run it, still I didn't get any results.
I used xvfb also to run the gtk application using xvfb-run ./(gtk application) command but nothing seems to be promising
Any suggestions would be appreciated.
Thanks
