I need to set up an automatic sync between a folder on my Disk and my google Drive, that runs every day, using FreeFileSync.
I created a batch job from FreeFileSync, named syncDrive.ffs_batch, and saved in my FreeFileSync installation folder /home/$USER/bin/FreeFileSync.
the job doesn't work for some reason. I've set up the crontab file as follows:
DISPLAY=:10.0
0 18 * * * /home/$USER/bin/FreeFileSync/syncDrive.ffs_batch
if I manually run the script from terminal, i get a permission error. If i run it with sudo, it says command not found.
Anyone knows how to fix? thanks in advance. Using Ubuntu 19.10
