I have been confronted with this GUI:
There is a question about that here, and trying to provide an answer in order to avoid any confusion for a beginner, I simply ended up asking myself whether that installer setting could be confusing by itself (I mean the result of a confusion in design).
No matter the selection made there only one partition is created, even if "logical" is the one selected: the system is installed on a logical partition that fills an entire extended partition. The installer not only tell us nothing about extended partitions (we are supposed to know that "logical" necessarily means an extended partition there too), and no extended-logical structure is displayed in the graphical scheme we see there, but we are never asked if we want more than one logical partition.
I'm not sure in what Ubuntu version that GUI is present with exactly that options, and I am not confronted with this situation as I write this, I have just been remembered by the other question (that I was trying to answer) the multiple times when I have found myself with a system installed on an extended partition (that is, a logical one that fills an entire extended one).
The fact that the installer doesn't ask if we want more than one logical partition within that extended one, and simply creates one logical that fills the entire extended partition is confusing. What could be the use of that?
Isn't a logical partition (meaning also an extended one) serving a purpose only if we want more than one of that kind? What could be the use of an extended partition with only one logical? Shouldn't the choice be between a logical and an extended partition? And if the second was to be selected, shouldn't there be a new choice regarding the number of logical partitions?
As things are, the "logical" option results in a pointless scenario.
Oh, and furthermore: that is the default option! Even if this choice was justified, "primary" should be the default (already selected) option.
As the answer to the linked question says, "it does not matter much" logical or primary. I didn't gave it much attention myself, and realized I had useless (one-logical) extended partitions on my drive only when I opened a partition manager at a later time. But I ended up with a confusing image about these matters.
cipricus
  • 4,066
  • 47
  • 106
It breaks down to this...
Older computers have a BIOS, and use MBR disk partioning on the hard disk.
  • MBR partitioning only allows a maximum of 4 disk partitions
  • normally that translates to 3 primary partitions, and 1 extended partition that contains various logical partitions.
Newer computers have a UEFI system, and use GPT disk partioning on the hard disk.
  • GPT partitioning has no such partition limits, and normally only uses primary partitions.
When installing Ubuntu, you don't have to decide how to partition your hard disk, as Ubuntu will do that for you. Especially when using a small hard disk, or only one hard disk, there's really NO NORMAL REASON to manually partition the drive.
Update #1:
You're partially correct. Having an extended partition with only one logical partition doesn't make a whole lot of sense... as long as it has only one logical partition... but that's NOT normally the case.
Three more common scenarios end up with more logical partitions...
  1. Where the user has to create a logical swap partition for hibernation.
  2. Where the user has decided to have a separate / root partition, and a separate /home partition.
  3. Where the user has an extended partition, with only one logical partition, and later wishes to add additional logical partitions.
Also remember that fresh installs of current versions of Ubuntu prefer a /swapfile, unless it finds a prior swap partition.
heynnema
  • 73,649
After try, I found that ubuntu 20 will using gpt as default. In gpt partition, there is no difference between primary and logic partition:
$ sudo parted /dev/sdd
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags 1 1049kB 2097kB 1049kB bios_grub 2 2097kB 540MB 538MB fat32 EFI System Partition boot, esp 3 540MB 7540MB 7000MB ext4 4 7540MB 7551MB 10.5MB ext4 5 7551MB 7561MB 10.5MB ext4 6 7561MB 7572MB 10.5MB ext4 7 7572MB 7582MB 10.5MB ext4 8 7582MB 7602MB 19.9MB ext4 9 7602MB 7622MB 19.9MB ext4 10 7622MB 7642MB 19.9MB ext4 11 7642MB 7662MB 19.9MB ext4
In above result, 20MB is logic partition, 10MB is primary partition
And if you install on a mbr disk, if you want to have more than 4 partition, you must use logic partition. For the partition after fourth, even you choose primary, it still a logic partition, above 10MB is primary partition.
$ sudo parted /dev/sda
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags 1 1049kB 1000MB 999MB primary fat32 boot, esp 2 1000MB 8001MB 7000MB primary ext4 3 8001MB 8011MB 10.5MB primary ext4 4 8012MB 8081MB 69.2MB extended 5 8012MB 8031MB 18.9MB logical ext4 6 8032MB 8051MB 18.9MB logical ext4 7 8052MB 8071MB 18.9MB logical ext4 8 8072MB 8081MB 9437kB logical ext4
