I have Ubuntu 18 I have a skytraq gps with pl2303 converter attached to ttyUSB0 I can't make gpsd work I changed /etc/defaults/gpsd as:
# Default settings for the gpsd init script and the hotplug wrapper.
# Start the gpsd daemon automatically at boot time
START_DAEMON="true"
# Use USB hotplugging to add new USB devices automatically to the daemon
USBAUTO="true"
# Devices gpsd should collect to at boot time.
# They need to be read/writeable, either by user gpsd or the group dialout.
DEVICES="/dev/ttyUSB0"
# Other options you want to pass to gpsd
GPSD_OPTIONS="/dev/ttyUSB0"
GPSD_SOCKET="/var/run/gpsd.sock"
When I use xgps, no data, it does not work, so even navit does not work
guiverc
  • 33,561
Late, but hope not too late: If the pl2302 works on ttyUSB0 Check this
sudo cat /dev/ttyUSB0
The Different to your File is: GPSD_OPTIONS="-n"
Works on Ubuntu 18 ad 20
The example for my File with Navilock NL602 on /dev/ttyACM0 in commands olt gps-mouse NL302 /dev/ttyUSB0
#hier liegt die Datei /etc/default/gpsd
START_DAEMON="true"
USBAUTO="false"
#neue GPS-Mouse Navilock NL602U
DEVICES="/dev/ttyACM0"
#alte GPS-MMouse Navilock NL302U
#DEVICES="/dev/ttyUSB0"
GPSD_OPTIONS="-n"
Gerold
