I'm having trouble formatting my 16GB USB stick. I've gone through most of the previous questions on this topic, but I'm not able to do it. Badblocks showed no error, Gparted is unable to create partition table, and the Disks tool showing unallocated space in front of Contents.
I just want to format it as I have no important data in it.
akhilD
  • 184
I had the same problem. Do a search for using the non-graphical parted command for the task. I will not repeat the steps here, as you can easily find it. Basically, you put a partition on the drive followed by a file system. Then using the chmod command, give read and write permissions to the drive.
AlexP
