I am trying to setup ubuntu properly on ultrawide monitor.
What have I done so far:
  1. I have run:
    xrandr
    and found out that my connected monitor is HDMI-0:
    HDMI-0 connected 1920x1080+258+0 (normal left inverted right x axis y axis) 797mm x 333mm
    1920x1080     60.00*   50.00    59.94
    1680x1050     59.88
    1600x900      60.00
  2. Then I have run:
    gtf 3440 1440 60
    to find my Modeline for the 3440x1440 resolution that I want is and got this:
      # 3440x1440 @ 60.00 Hz (GTF) hsync: 89.40 kHz; pclk: 419.11 MHz
      Modeline "3440x1440_60.00" 419.11  3440 3688 4064 4688  1440 1441 1444 1490  -HSync +Vsync
  3. Next is to add that new mode:
    xrandr --newmode MODELINE GOES HERE
    which is in my case:
    xrandr --newmode "3440x1440_60.00" 419.11  3440 3688 4064 4688  1440 1441 1444 1490  -HSync +Vsync
  4. Then I added the mod with:
    xrandr --addmode HDMI-0 3440x1440_60
    Now, when I go to displays, I can find that mod on my ultrawide monitor
  5. After that I have run:
    xrandr --output HDMI-0 --mode 3440x1440_60
    and the monitor goes black, and I have to blindly type previous resolution to get it back.
The same happens if I select it from the Displays settings.
I am using Asus Laptop model a54h
Where is my mistake?
cheshire
  • 283
The steps above are correct. My laptop uses an AMD Radeon HD 7470M 1GB and the maximum digital resolution is 2560 x 1600. That is why I get a black screen when I try to set it above it.
cheshire
  • 283
For those of you that have this same issue with an ultra-wide resolution on Ubuntu, do this:
  1. Verify your graphics card can support the resolution by just googling the model # of your graphics card & "max resolution"
  2. Use the proper cable, displayport is the best option, HDMI is the second best option.
  3. Make sure you are using a video cable with no adapters. In other words, if your laptop has display port, dont use a display port to
    HDMI adapter. This was my issue. Once I used a straight display port-to-display port, everything worked flawlessly.
  4. If you have a non-Intel graphics card, then look into downloading the Ubuntu version of those drivers.
Good Luck
You created newmode named "3440x1440_60.00"
And tried to addmode called HDMI-0 3440x1440_60
Names dont match 3440x1440_60!=3440x1440_60.00
However, although the option of 3440x1440 appears in the settings, system still returns to lower after applying it :/
