I am facing an issue so strange in Xubuntu 18.04... I ran the following command after sudo apt update :
sudo apt upgrade
But it leads to an error :
 linux-image-5.0.0-36-generic : Depends: linux-modules-5.0.0-36-generic but it is not going to be installed
E: Broken packages
I assume that I must install linux-modules-5.0.0-36-generic, but I am not sure and I would do bad things... I am just a beginner in Linux environment.
Some details :
uname -a
>>Linux mistapopo-Aspire-A515-52G 5.0.0-37-generic #40~18.04.1-Ubuntu SMP Thu Nov 14 12:06:39 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
When I run the following commands
sudo apt update
sudo apt dist-upgrade
I get the following log :
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following package was automatically installed and is no longer required:
  libllvm8
Use 'sudo apt autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
5 not fully installed or removed.
Need to get 0 B/8 426 kB of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
Setting up linux-image-unsigned-5.3.1-050301-generic (5.3.1-050301.201909210632) ...
Setting up linux-image-5.3.0-28-generic (5.3.0-28.30~18.04.1) ...
Setting up linux-image-5.3.0-26-generic (5.3.0-26.28~18.04.1) ...
Setting up linux-image-unsigned-5.3.1-050301-lowlatency (5.3.1-050301.201909210632) ...
Processing triggers for linux-image-unsigned-5.3.1-050301-generic (5.3.1-050301.201909210632) ...
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-5.3.1-050301-generic
/etc/kernel/postinst.d/zz-update-grub:
Sourcing file `/etc/default/grub'
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-5.3.1-050301-lowlatency
Found initrd image: /boot/initrd.img-5.3.1-050301-lowlatency
Found linux image: /boot/vmlinuz-5.3.1-050301-generic
Found initrd image: /boot/initrd.img-5.3.1-050301-generic
Found linux image: /boot/vmlinuz-5.3.0-28-generic
Found initrd image: /boot/initrd.img-5.3.0-28-generic
Found linux image: /boot/vmlinuz-5.3.0-26-generic
Found initrd image: /boot/initrd.img-5.3.0-26-generic
Found linux image: /boot/vmlinuz-5.0.0-37-generic
Found initrd image: /boot/initrd.img-5.0.0-37-generic
Found linux image: /boot/vmlinuz-5.0.0-36-generic
Found Windows Boot Manager on /dev/sda1@/EFI/Microsoft/Boot/bootmgfw.efi
Adding boot menu entry for EFI firmware configuration
/usr/sbin/grub-mkconfig: 295: /usr/sbin/grub-mkconfig: /usr/bin/grub-script-check: not found
Syntax errors are detected in generated GRUB config file.
Ensure that there are no errors in /etc/default/grub
and /etc/grub.d/* files or please file a bug report with
/boot/grub/grub.cfg.new file attached.
run-parts: /etc/kernel/postinst.d/zz-update-grub exited with return code 1
dpkg: error processing package linux-image-unsigned-5.3.1-050301-generic (--configure):
 installed linux-image-unsigned-5.3.1-050301-generic package post-installation script subprocess returned error exit status 1
Processing triggers for linux-image-5.3.0-28-generic (5.3.0-28.30~18.04.1) ...
update-initramfs: Generating /boot/initrd.img-5.3.0-28-generic
dpkg: error processing package linux-image-5.3.0-28-generic (--configure):
 installed linux-image-5.3.0-28-generic package post-installation script subprocess returned error exit status 1
Processing triggers for linux-image-5.3.0-26-generic (5.3.0-26.28~18.04.1) ...
update-initramfs: Generating /boot/initrd.img-5.3.0-26-generic
dpkg: error processing package linux-image-5.3.0-26-generic (--configure):
 installed linux-image-5.3.0-26-generic package post-installation script subprocess returned error exit status 1
Processing triggers for linux-image-unsigned-5.3.1-050301-lowlatency (5.3.1-050301.201909210632) ...
update-initramfs: Generating /boot/initrd.img-5.3.1-050301-lowlatency
dpkg: error processing package linux-image-unsigned-5.3.1-050301-lowlatency (--configure):
 installed linux-image-unsigned-5.3.1-050301-lowlatency package post-installation script subprocess returned error exit status 1
No apport report written because MaxReports is reached already
Mistapopo
  • 113
original answer that applies to most users:
When dpkg tries to finish the installation configuration for the kernel it runs grub-script-check when running grub-mkconfig to auto-generate /boot/grub/grub.cfg. If there is a problem with your configuration files, it will return this error. The error says that you have a syntax problem in /etc/default/grub or one of your other grub configuration files in your /etc/default/grub.d directory.
If you recently made changes to any of your grub configuration files like /etc/default/grub or any other file in your /etc/default/grub.d directory, you need to correct or delete the changes made.
After you fix the file or files, run the following command:
sudo dpkg --configure -a
or
sudo apt -f install
See this answer and this detailed example for more information about the grub syntax error.
UPDATE:
Run the following command:
file /usr/bin/grub-script-check
If it returns "no such file or directory" then run:
sudo apt install --reinstall grub-common
Then, run:
or
sudo apt -f install
Whenever you have a "not found" error you can search for the package name that contains the file at packages.ubuntu.com or you can use the apt-file application but to install apt-file you have to first enable the universe repository: sudo add-apt-repository; sudo apt update.
Here's how I figured it out.
Starting at the end of your output we see two pretty generic errors that doesn't really tell us anything:
and
Now when we scroll up, we see an actual error that tells us something (syntax error):
Just above this line, we see exactly when this error occurred:
Now, a file name followed by "not found" usually means a missing file but we also have the syntax error indicating a problem in one of the grub config files.
A number after a file name (/usr/sbin/grub-mkconfig: 295) usually indicates the line number of the file so I looked up the file /usr/sbin/grub-mkconfig and on line 295, it references grub_script_check (/usr/bin/grub-script-check) and later it says to return a syntax error if anything is returned.
In this case, the syntax error wasn't returned by the grub-script-check command, the error was returned by the fact that the grub-script-check command was not found so there was no actual syntax error.
mchid
  • 44,904
  • 102
  • 162
