Recently I've got a Razer Blade 15 system (Mid 2019), installed Ubuntu 19.10 and everything works fine except one thing.
When I suspend the laptop (lock + closing the lid), I get some problems after waking it up.
First thing - touchpad is not working. I've found workaround - touchpad works, but there is another bigger problem. After one minute or so computer automatically suspends again. Doesn't matter if I am doing anything or not.
Do you have any idea what can cause this problem? Currently I used "Tweaks" to turn off suspending on lid closing, but that's temporary solution.
EDIT: After more testing - problem only occurs when suspend is triggered by closing the lid. Auto suspend after time and suspending with power button doesnt cause the problem.
McCease
Editing the GRUB boot parameters as suggested in Sleep issues on my Razer Blade Stealth. 16.04 LTS fixed this for me (on 20.04).
  1. Open a terminal and run:
    sudo nano /etc/default/grub
  2. Change the line beginning GRUB_CMDLINE_LINUX_DEFAULT= to include the parameter button.lid_init_state=open, so for example it may read:
    GRUB_CMDLINE_LINUX_DEFAULT="button.lid_init_state=open"
    Existing parameters such as quiet splash etc can be left as they are. Parameters should be separated by spaces within the double quotes.
  3. Update GRUB with the following command in the terminal:
    sudo update-grub
  4. Restart.
Zanna
  • 72,312
