Today I booted my PC and the resolution of the screen was different to what it was when I turned it off yesterday, so I wanted to used xrandr to change it back, but then I saw this output:
$ xrandr
Screen 0: minimum 320 x 200, current 3840 x 2160, maximum 16384 x 16384
DisplayPort-0 disconnected primary (normal left inverted right x axis y axis)
DisplayPort-1 disconnected (normal left inverted right x axis y axis)
DisplayPort-2 disconnected 3840x2160+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
HDMI-A-0 disconnected (normal left inverted right x axis y axis)
3840x2160 (0x5a) 533.250MHz +HSync -VSync
h: width 3840 start 3888 end 3920 total 4000 skew 0 clock 133.31KHz
v: height 2160 start 2163 end 2168 total 2222 clock 60.00Hz
Notice it says all screens are disconnected, even though I know at least one screen is connected as I'm using it. The screen attached to DisplayPort-2 is the one that should be in use.
I unplugged the cable and plugged it back, and now xrtandr shows the right info:
$ xrandr
DisplayPort-2 connected 3840x2160+0+0 (normal left inverted right x axis y axis) 607mm x 345mm
3840x2160 60.00*+ 30.00 29.97
2560x1440 59.95
1920x1200 60.00
1920x1080 60.00 59.94
1600x1200 60.00
1680x1050 59.95
1600x900 60.00
1280x1024 75.02 60.02
1440x900 59.89
1280x800 59.81
1152x864 75.00
1280x720 60.00 59.94
1024x768 75.03 70.07 60.00
832x624 74.55
800x600 72.19 75.00 60.32 56.25
640x480 75.00 72.81 66.67 60.00 59.94
720x400 70.08
What can cause xrandr to not recognize the screen? And why could my screen resolution had changed out of the blue?
Thanks.
Other info:
- I'm using Ubuntu 18.04.3 LTS.
- My video card is a Radeon RX 480
uname -ryields4.15.0-74-generic
