I am facing a weird problem in gnome startup. Gnome startup gets stuck (before login screen) on battery BUT not when my laptop is connected to power.
I am running ubuntu 18.04 on Thinkpad T495 (AMD ryzen 3500u pro). Recently upgraded to the latest 5.3 kernel (via bionic stable ppt).
Linux ThinkPad-T495 5.3.0-26-generic #28~18.04.1-Ubuntu SMP Wed Dec 18 16:40:14 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
I was checking the journalctl logs but I am not entirely sure what sort of errors I need to focus on.
Any help on this is much appreciated!
UPDATE:
This issue persists in ubuntu 20.04 as well.
And adding grub params iommu=soft solves this at least temporarily.
n1r44
  • 151
Same bug on pretty much every distro I could try, s340 with 3500u here. Is this a known issue for the devs?
Edit: adding grub params nomodeset or iommu=soft solves this (idk at what cost) but it is a good temporary fix
Gryu
  • 8,002
  • 37
  • 53
Installed Kernel 5.5 according to this guide: http://ubuntuhandbook.org/index.php/2020/01/install-kernel-5-5-ubuntu/
Currently running 5.5.0-050500-generic which appears to resolve the issue. I am able to boot my laptop (T495/Ryzen) on battery now and did not see any other problems so far. USB works for me.
Only one error message remains in journalctl
[drm:dm_helpers_parse_edid_caps [amdgpu]] *ERROR* Couldn't read SADs: -2
Martin
I disabled IOMMU in my bios and the laptop boots perfectly on battery now.
Zanna
  • 72,312
You can install the new 5.8 kernel with:
sudo apt install linux-generic-hwe-20.04-edge
be aware that this is official experimental kernel until they release the non-edge.
Xwayland edge still not out.
It will fix the problem, although I have another problem now with USB and BT suspending after a while.
Zanna
  • 72,312
Rudi
