I had ubuntu set up on my ssd, and tried to install windows over it and now I can't even run ubuntu. I'm not sure what I should do, with no usbs in I cant get past BIOS (Gigabyte). I'm not good with BIOS to start with, but ubuntu is coming up in my boot sequence but my pc won't boot from it?
I hope I'm making sense, appreciate any help
For installing Windows by removing Ubuntu follow this steps:
  1. Take a backup of your data to external drive.
  2. Reboot the PC.
  3. Insert Windows CD/Pendrive and select boot device as same.
  4. When you see the "Windows Setup window". Press Shift + F10 keys together on the keyboard, which will take you to command prompt. Enter DISKPART command
  5. Enter list disk command to list the available disks along with your CD/Pendrive.
  6. Enter select DiskX command- here X is your disk number(Mostly which has large size).
  7. Enter clean command (If it doesn't work enter diskclean), which erases all the data then exit the terminal.
  8. Install OS by doing partitions (follow the steps in https://www.partitionwizard.com/partitionmanager/install-windows-10.html).
Kurtoid
  • 604
