Trying to install pdfbeads on Ubuntu LTS 16.04 with the command $ gem install pdfbeads I'm getting the error message "ERROR: Can't install RMagick 4.0.0. Can't find ImageMagick with pkg-config"
Below between the separators is the corresponding stdout.
$ sudo gem install pdfbeads
Building native extensions. This could take a while... Successfully installed nokogiri-1.10.7 Building native extensions. This could take a while... ERROR: Error installing pdfbeads: ERROR: Failed to build gem native extension.
current directory: /home/enemem/.gem/gems/rmagick-4.0.0/ext/RMagick
/snap/bin/ruby -I /snap/ruby/172/lib/ruby/2.7.0 -r ./siteconf20200127-10722-yuiix4.rb extconf.rb checking for brew... no checking for pacman... no checking for gcc... yes checking for pkg-config... yes
* extconf.rb failed * Could not create Makefile due to some reason, probably lack of necessary libraries and/or headers. Check the mkmf.log file for more details. You may need configuration options.
Provided configuration options: --with-opt-dir --without-opt-dir --with-opt-include --without-opt-include=${opt-dir}/include --with-opt-lib --without-opt-lib=${opt-dir}/lib --with-make-prog --without-make-prog --srcdir=. --curdir --ruby=/snap/ruby/172/bin/$(RUBY_BASE_NAME)
Checked the mkmf.log file but it containe the same info, verbatim.
Then I tried to use the command
$ pkg-config --modversion imagemagick
and got this output:
Package imagemagick was not found in the pkg-config search path. Perhaps you should add the directory containing `imagemagick.pc' to the PKG_CONFIG_PATH environment variable No package 'imagemagick' found
Following up on this suggestion I tried to find where imagemagick is on my system by running:
$ sudo locate -b '\imagemagick*'
and got the output:
/usr/lib/mime/packages/imagemagick /usr/share/app-install/desktop/imagemagick-6.q16:display-im6.q16.desktop /usr/share/app-install/desktop/imagemagick:display-im6.desktop /usr/share/bug/imagemagick /usr/share/cups/ppdc/imagemagick.defs /usr/share/doc/imagemagick /usr/share/doc/imagemagick-6.q16 /usr/share/doc/imagemagick-common /usr/share/menu/imagemagick /var/lib/app-info/icons/ubuntu-xenial-main/64x64/imagemagick-6.q16_display-im6.q16.png /var/lib/app-info/icons/ubuntu-xenial-main/64x64/imagemagick_display-im6.q16.png /var/lib/app-info/icons/ubuntu-xenial-security-main/64x64/imagemagick-6.q16_display-im6.q16.png /var/lib/app-info/icons/ubuntu-xenial-security-main/64x64/imagemagick_display-im6.q16.png /var/lib/app-info/icons/ubuntu-xenial-updates-main/64x64/imagemagick-6.q16_display-im6.q16.png /var/lib/app-info/icons/ubuntu-xenial-updates-main/64x64/imagemagick_display-im6.q16.png /var/lib/dpkg/info/imagemagick-6.q16.list /var/lib/dpkg/info/imagemagick-6.q16.md5sums /var/lib/dpkg/info/imagemagick-common.conffiles /var/lib/dpkg/info/imagemagick-common.list /var/lib/dpkg/info/imagemagick-common.md5sums /var/lib/dpkg/info/imagemagick-common.postinst /var/lib/dpkg/info/imagemagick-common.postrm /var/lib/dpkg/info/imagemagick-common.preinst /var/lib/dpkg/info/imagemagick.list /var/lib/dpkg/info/imagemagick.md5sums /var/lib/dpkg/info/imagemagick.postinst /var/lib/dpkg/info/imagemagick.postrm /var/lib/dpkg/info/imagemagick.prerm
Version of the imagemagick package on my system is 6.8.9.9
$ sudo apt search ImageMagick | grep installed
imagemagick/xenial-updates,xenial-security,now 8:6.8.9.9-7ubuntu5.15 amd64 [installed] imagemagick-6.q16/xenial-updates,xenial-security,now 8:6.8.9.9-7ubuntu5.15 amd64 [installed] imagemagick-common/xenial-updates,xenial-updates,xenial-security,xenial-security,now 8:6.8.9.9-7ubuntu5.15 all [installed] libgraphicsmagick++-q16-12/xenial-updates,xenial-security,now 1.3.23-1ubuntu0.5 amd64 [installed,automatic] libgraphicsmagick-q16-3/xenial-updates,xenial-security,now 1.3.23-1ubuntu0.5 amd64 [installed,automatic] libimage-magick-perl/xenial-updates,xenial-updates,xenial-security,xenial-security,now 8:6.8.9.9-7ubuntu5.15 all [installed,automatic] libimage-magick-q16-perl/xenial-updates,xenial-security,now 8:6.8.9.9-7ubuntu5.15 amd64 [installed,automatic] libmagick++-6.q16-5v5/xenial-updates,xenial-security,now 8:6.8.9.9-7ubuntu5.15 amd64 [installed,automatic] libmagickcore-6.q16-2/xenial-updates,xenial-security,now 8:6.8.9.9-7ubuntu5.15 amd64 [installed] libmagickwand-6.q16-2/xenial-updates,xenial-security,now 8:6.8.9.9-7ubuntu5.15 amd64 [installed] perlmagick/xenial-updates,xenial-updates,xenial-security,xenial-security,now 8:6.8.9.9-7ubuntu5.15 all [installed,automatic]
Can anyone help?
EDIT : Please install libmagickcore-6.q16-dev (8:6.8.9.9-7ubuntu5.15), which is the development files for your installed "imagemagick (8:6.8.9.9-7ubuntu5.15)" : /usr/lib/x86_64-linux-gnu/pkgconfig/ImageMagick.pc, etc. etc. files.
https://packages.ubuntu.com/xenial-updates/libmagickcore-6.q16-dev >>> https://packages.ubuntu.com/xenial-updates/amd64/libmagickcore-6.q16-dev/filelist
May be you have to uninstall the older version graphicsmagick-libmagick-dev-compat and the dependency libgraphicsmagick1-dev.
Knud Larsen
  • 3,134
