I have a strange situation here. If anyone can help, please do so.
We're talking about a Linux Box running as Router using Ubuntu 18.04.3 LTS, with 2 interfaces: "lan" - which connects to my internal LAN and "wan" - which connects to my ISP.
However, my ISP requires PPPoE connection, so, basically, the "wan" interface is used only a starter for the ppp0 interface.
My problem is that I cannot get IPv6 global address on this server.
I am able to successfully connect to my ISP. I already followed the tutorial from here: http://gruffi.be/mediawiki/index.php/Ipv6_with_PPPoE_on_Ubuntu , but it doesn't work for me.
So, here is what I did:
/etc/ppp/options:
+ipv6 ipv6cp-use-ipaddr/etc/sysctl.conf:
net.ipv6.conf.all.forwarding=1 net.ipv6.conf.ppp0.accept_ra=2/etc/wide-dhcpv6/dhcp6c.conf:
interface ppp0 { send ia-pd 2; send ia-na 1; }; # Use subnets from the prefix with id 0 id-assoc pd 2 { prefix-interface lan { # Assign subnet 1 to eth0 sla-len 8; # <----- BELANGRIJK: 8 omdat ons klein net 64 en ons groot 56 is en dat het verschil is sla-id 2; }; }; id-assoc na 1 { };/etc/radvd.conf:
interface lan { AdvSendAdvert on; prefix ::/64 { AdvOnLink on; AdvAutonomous on; AdvRouterAddr on; }; RDNSS 2001:4860:4860::8888 2001:4860:4860::8844 { # AdvRDNSSLifetime 3600; }; };
My ISP told me that it doesn't use Router Advertisement, however it uses DHCPv6 Prefix Delegation and offers /64 subnets.
The problem is that I tried more configs from the net, non of them worked for me.
When I "ifconfig ppp0", it says:
inet 1.2.3.4 ...
inet6 fe80::xxxx:yyyy
No sign of a global IPv6 address.
If I turn on debugging on wide DHCP client and I examine /var/log/syslog, I see that it tries to send Solicit messages to ff02::1:2%ppp0 and the timers reset. I get no reply.
However, router advertisements are working, both on "ppp0" and on my internal lan, because I have a Default Route: "default via fe80::1" when I "ip -6 r". However, no global IPv6 address.
I suspect it something to do with DHCP. The address is not obtained correcly.
I can ping:
ping6 fe80::1%ppp0
64 bytes from...
But when trying to "ping6 google.com", it says: "Beyond scope of source address"
I need to do 2 things, in the long run:
Try to get a global IPv6 address on "ppp0" so my websites can be accesible from IPv6 addresses (DNS already taken care of)
I need to forward whatever /64 prefix my ISP gives me, let's say: "2001:abcd:dead:beef::/64" to my internal computers, but using a fixed part for the internal computers.[/COLOR]
For example:
Computer 1: 2001:abcd:dead:beef::1/64
Computer 2: 2001:abcd:dead:beef::2/64
Computer 3: 2001:abcd:dead:beef::3/64
I do NOT want EUI-64 addresses, NOR do I want Private Addresses. I want my computers assigned an ORDERly IPv6 address with the prefix given, regardless of the dynamic prefix.
For example, after reboot, I might get "2001:1234:beef:dead::/64". I want the same Host-part allocation using "::1", "::2", and so on...
Thank you !
