My GSM modem is attached to ttyUSB2 port but I am not able to access the port for AT commands. When I try to access it I get an error as below:
$ sudo minicom
Device /dev/ttyUSB2 is locked.
Zanna
  • 72,312
srg
  • 123
Do ps -ef and see if there is any minicom -s process running.
If there is then kill that process with kill -9 pid where pid is the PID number given in the output of ps -ef. It will solve your problem.
Zanna
  • 72,312
Read man minicom. It says. in part:
     B - Lock file location
          On most systems This should be /usr/spool/uucp. GNU/Linux systems use /var/lock. If
          this directory does not exist, minicom will not attempt to use lockfiles.
So, look for lock files in /var/lock or /usr/spool/uucp
waltinator
  • 37,856
