25
I am running 18.04.3 LTS on my main computer:
# lsb_release -a
LSB Version:    core-9.20170808ubuntu1-noarch:security-9.20170808ubuntu1-noarch
Distributor ID: Ubuntu
Description:    Ubuntu 18.04.3 LTS
Release:        18.04
Codename:       bionic
On a new computer I am installing 18.04.3 LTS and was suprised that it had a different kernel. The new install is using vmlinuz-5.3.0-26-generic, but my (updated/upgraded/etc..) current computer is only on vmlinuz-4.15.0-74-generic.
How can I figure out what is holding my computer back from upgrading?
I don't seem to have anything pinned for the kernel:
# dpkg --get-selections linux
dpkg: no packages found matching linux
Ubuntu 18.04 LTS users have two software stacks to choose from, maximum stability with the original software stack (4.15 kernel), or the moving HWE (hardware enablement stack) which uses the 18.10, then 19.04, 19.10, and eventually settles on 20.04 software stack.
https://wiki.ubuntu.com/Kernel/LTSEnablementStack
Upgrades from prior releases using the stable option (4.15), as do installs using 18.04, or 18.04.1 media. They can opt to enable HWE though.
Installs using 18.04.2 or later media start with HWE enabled.
18.04.2 uses the 18.10 software stack. 18.04.3 uses the 19.04 software stack. 18.04.4 uses the 19.10 software stack (currently in testing). until the stack becomes static using the 20.04 base kernel.
From the provided link, to enable HWE use
DESKTOP
 sudo apt-get install --install-recommends linux-generic-hwe-18.04 xserver-xorg-hwe-18.04
SERVER sudo apt-get install --install-recommends linux-generic-hwe-18.04
guiverc
  • 33,561
