Context
The Boot goes fine, the connected ethernet connects and system-wize everything is up and running. The login fails however. I'm trying to login using
  • user: ubuntu
  • pass: ubuntu
as per instructions on https://ubuntu.com/download/raspberry-pi I'm however greeted by the username or password incorrect message. Upon checking the user-data file on the sd-card reveals the following configuration:
# On first boot, set the (default) ubuntu user's password to "ubuntu" and
# expire user passwords
chpasswd:
  expire: true
  list:
  - ubuntu:ubuntu
So by all means logging in should have worked, what am I doing wrong here?
Figured it out by accident. apparently the default login doesn't work on TTY0 (the default that the raspberry pi boots with), switching to TTY1 or above and retrying to login solves all problems.
the curse does not move when entering password. type it anyway and pay attention to what you type. I did this with pi3b hooked to a older tv, and the first three spaces was blocked out by the tv frame. it took several tries before i noticed it was asking for a new password. type it in, curse will not move, press enter
