OS: Ubuntu 11.10 with gnome-shell
I've few access points on my saved list which I want to remove and never connect to. I can't seem to find way to delete these.
How should I remove (at least not auto connect) from saved access point list?
ctrl + t {for terminal prompt}
cd /etc/NetworkManager/system-connections
sudo rm {wireless_hotspot_name}
Hope that helps
EDIT FROM ONE YEAR LATER
Seems like this turned into a fairly popular answer, so I went ahead and wrote an automated script to do this for everyone. Just copy the below script into into /usr/local/bin/wireless and remember to run command sudo chmod +x /usr/local/bin/wireless
Glad to see this is continually helping fellow *buntu users ;) newest version(s) will be on GitHub
#!/bin/bash
# Review and Remove Wireless Access Points on DEB based Systems
# Make sure to place script in /usr/local/bin
# CPR : Jd Daniel :: GabelBombe
# MOD : 2013-12-09 @ 12:27:02
# INP : $ wireless -{flag} {arg}
clear
# If the user is not root
if [ "$(id -u)" != "0" ]; then
echo "This script must be run as root" 1>&2 ; exit 1
fi
declare -r VERSION='1.2b'
declare -r net_dir='/etc/NetworkManager/system-connections'
function list ()
cd "${net_dir}"
export count=$(ls |wc -l) # used in drop function
files=$(ls) # simple ls
echo -e "\n\tFound ${count} wireless connections"
for f in $files; do
echo -e "\t * $f"
done
function drop ()
# make sure that we have a working file and directory...
cd "${net_dir}" ; [ -f "$OPTARG" ] || { echo -e "\n\tConnection does not exist..." ; exit 1; }
# confirmation for removal
printf "\n\tDo you want to delete $OPTARG [y/n] " ; read -r resp
# strtolower, and rm
if [ 'y' == "$(echo $resp | awk '{print tolower($0)}')" ]; then
rm -f ${net_dir}/${OPTARG}
fi
function flush ()
# make sure that we have a directory with files...
cd "${net_dir}" ; list ; [ 0 -ge "${count}" ] && { echo -e "\tExiting, Nothing to flush..." ; exit 1 ; }
# confirmation for removing all files
printf "\n\tAll Wireless Connections will be removed, continue? [y/n] " ; read -r resp
rm -f ${net_dir}/*
fi
function version ()
echo -e "\n\twireless (GNU wireless network purge) v${VERSION}"
echo -e "\n\tCopyright (C) 2013 Hydra Code, LLC."
echo -e "\tLicense GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>.\n\tThis is free software: you are free to change and redistribute it.\n\tThere is NO WARRANTY, to the extent permitted by law."
echo -e "\n\n\tWritten by Jd Daniel (GabelBombe) http://github.com/GabelBombe"
exit 0
function help ()
echo -e "\n\tUsage: wireless [OPTION]... [FILE]..."
echo -e "\tList, remove single or flush the contents of your Wireless Network Manager"
echo -e "\n\tThe options below may be used to perform the above actions, this program will only"
echo -e "\trun a single flag or parameter at a time. Flag chaining is only available for -d"
echo -e "\t -l, --list \t\t List the contents of your 'Network Manager'"
echo -e "\t -d, --drop [conn] \t Drop a single (or multiple) wireless connections"
echo -e "\t -f, --flush \t\t Flush all wireless connections."
echo -e "\t --help \t\t Display this help menu and exit"
echo -e "\t --version \t Display version information and exit"
exit 0
# no long-opts supported except --help
while getopts ':ld:f-:' OPT; do
case $OPT in
l) list ;;
d) dirList="${dirList} $OPTARG" ; drop ;;
f) flush ;;
-) #long option
case $OPTARG in
list) list ;;
drop) drop ;;
flush) flush ;;
help) help ;;
version) version ;;
esac
: ) echo -e "\n\tMissing option argument for -$OPTARG" >&2; exit 1;;
* ) echo -e "\n\tUnknown flag supplied ${OPTARG}\n\tTry wireless --help"; exit 1;;
esac
done
shift $(($OPTIND - 1))
Delete all connection never used ( no root needed )
nmcli --fields UUID,TIMESTAMP-REAL con show | grep never | awk '{print $1}' | while read line; do nmcli con delete uuid $line; done
Open Network Manager , If you use it its the applet on the top corner . Go to the edit connections menu and click on the wireless tab. Simply delete all the access points you dont need.
It seems that from the menu "Edit connections", that you can find clicking on the icon on the top panel (Ubuntu Unity), you can delete only wireless connections. If you have other networks like phone networks you have to delete them in the /etc/NetworkManager/system-connections folder. You have to become root to delete any subfolder in that folder.
For example to remove the network of my HTC evo I had to do:
sudo rm -R /etc/NetworkManager/system-connections/Network\ HTC\ EVO\ 3D\ X515m
Aside from the options mentioned in the other answers, you can also use the Network Manager app to forget the network or make it avoid automatic connections, in case you want to keep the network information.
