-1
I am using ubuntu 19.04. I want to delete fully and install fresh Ubuntu 18.04. And also I don't want to keep any information ,data inside it. When I searched in internet for the Installation type that is partitioning part, I became fully confused. Can you kindly tell me how should I partition hard disk. Swap partition, home partition, ext4 partition in details. Remember I don't want to keep neither 19.04 version neither any data in my laptop. Thanks in advance.
Default Ubuntu installation options are pretty much all you need.
Reinstall, and on the "Installation type" step choose:
"Erase disk and install Ubuntu"
I used this default installation method on my 120GB (111.76GiB) SSD and the following partitions were created:
$ sudo parted -l
Model: ATA Samsung SSD 850 (scsi)
Disk /dev/sda: 120GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number  Start   End    Size   File system  Name                  Flags
 1      1049kB  538MB  537MB  fat32        EFI System Partition  boot, esp
 2      538MB   112GB  111GB  ext4
Where:
1. Boot/EFI partition (fat32)
2. Root (/) partition (ext4) (for everything else)
Note: From Ubuntu 18.04 a swap file rather than a swap partition is used.
With 8GB of memory, the default installation created the following swap file:
$ cat /proc/swaps
Filename                Type        Size    Used    Priority
/swapfile               file        2097148 308     -2
https://tutorials.ubuntu.com/tutorial/tutorial-install-ubuntu-desktop#5
Broadsworde
  • 4,532
Unless you have a specific use for Ubuntu, it's pretty safe to just go and use the automatic partitioner with or without LVM (without LVM = easier to restore data).
Stefano Martins
  • 272
