I'm using Ubuntu 18.04.3, this one I installed last November and never have any problem so far.
Just around an hour ago after I restart my PC to clear some GPU memory, I found Google Chrome missing, I install that from .deb file and then then found out that the LAN menu went missing as well and I have to use wifi shered from phone now.
I didn't even run a single sudo in that session, just run some Python and Dota in steam. The only thing that not normal is that Tensorflow raise core dumped more often but I fixed it according to this, so I don't think this is related.
Later I found out that Redshift and VSCode are missing as well, from both terminal and launcher, don't know if there's anything else though. Checked it later and found out that VLC is gone too and got unmet dependencies so I can't re-install it.
The software's' setting are all safe and sound.
What's went wrong here exactly and also, how to bring the LAN back? Also some other softwares that suddenly have unmet dependencies.
My LAN works fine when I switch to Windows 10 though.
Software&Update somehow looks like this. I can only thick the Continue... but cannot Apply Changes, cannot thick anything else either. enter image description here
I got this when run sudo lshw -c network
  *-network DISABLED
       description: Ethernet interface
       product: Ethernet Connection (2) I219-V
       vendor: Intel Corporation
       physical id: 1f.6
       bus info: pci@0000:00:1f.6
       logical name: enp0s31f6
       version: 00
       serial: 70:85:c2:43:aa:f3
       capacity: 1Gbit/s
       width: 32 bits
       clock: 33MHz
       capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=3.2.6-k firmware=0.2-4 latency=0 link=no multicast=yes port=twisted pair
       resources: irq:123 memory:df300000-df31ffff
The word DISABLED is gone once I run sudo ip link set dev enp0s31f6 up but nothing else happens. The network menu still not show up and it goes back to DISABLED after I restart.
This doesn't work neither does this nor this.
Got this after run sudo smartctl --all /dev/nvme0n1
smartctl 6.6 2016-05-31 r4324 [x86_64-linux-5.0.0-37-generic] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Number:                       Samsung SSD 960 EVO 250GB
Serial Number:                      S3ESNX0J827730H
Firmware Version:                   2B7QCXE7
PCI Vendor/Subsystem ID:            0x144d
IEEE OUI Identifier:                0x002538
Total NVM Capacity:                 250,059,350,016 [250 GB]
Unallocated NVM Capacity:           0
Controller ID:                      2
Number of Namespaces:               1
Namespace 1 Size/Capacity:          250,059,350,016 [250 GB]
Namespace 1 Utilization:            118,155,931,648 [118 GB]
Namespace 1 Formatted LBA Size:     512
Local Time is:                      Mon Jan 20 21:21:19 2020 +07
Firmware Updates (0x16):            3 Slots, no Reset required
Optional Admin Commands (0x0007):   Security Format Frmw_DL
Optional NVM Commands (0x001f):     Comp Wr_Unc DS_Mngmt Wr_Zero Sav/Sel_Feat
Maximum Data Transfer Size:         512 Pages
Warning  Comp. Temp. Threshold:     77 Celsius
Critical Comp. Temp. Threshold:     79 Celsius
Supported Power States
St Op     Max   Active     Idle   RL RT WL WT  Ent_Lat  Ex_Lat
 0 +     6.04W       -        -    0  0  0  0        0       0
 1 +     5.09W       -        -    1  1  1  1        0       0
 2 +     4.08W       -        -    2  2  2  2        0       0
 3 -   0.0400W       -        -    3  3  3  3      210    1500
 4 -   0.0050W       -        -    4  4  4  4     2200    6000
Supported LBA Sizes (NSID 0x1)
Id Fmt  Data  Metadt  Rel_Perf
 0 +     512       0         0
=== START OF SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART/Health Information (NVMe Log 0x02, NSID 0x1)
Critical Warning:                   0x00
Temperature:                        44 Celsius
Available Spare:                    100%
Available Spare Threshold:          10%
Percentage Used:                    8%
Data Units Read:                    18,188,664 [9.31 TB]
Data Units Written:                 35,014,889 [17.9 TB]
Host Read Commands:                 298,357,165
Host Write Commands:                120,009,033
Controller Busy Time:               1,622
Power Cycles:                       1,580
Power On Hours:                     1,126
Unsafe Shutdowns:                   73
Media and Data Integrity Errors:    0
Error Information Log Entries:      1,388
Warning  Comp. Temperature Time:    0
Critical Comp. Temperature Time:    0
Temperature Sensor 1:               44 Celsius
Temperature Sensor 2:               51 Celsius
Error Information (NVMe Log 0x01, max 64 entries)
Num   ErrCount  SQId   CmdId  Status  PELoc          LBA  NSID    VS
  0       1388     0  0x00a0  0x4212  0x028            0     -     -
  1       1387     0  0x0020  0x4004  0x02c            0     0     -
  2       1386     0  0x001f  0x4004  0x02c            0     0     -
  3       1385     0  0x0002  0x4004  0x028            0     0     -
  4       1384     0  0x0020  0x4004  0x02c            0     0     -
  5       1383     0  0x001f  0x4004  0x02c            0     0     -
  6       1382     0  0x0002  0x4004  0x028            0     0     -
  7       1381     0  0x009a  0x4212  0x028            0     -     -
  8       1380     0  0x0020  0x4004  0x02c            0     0     -
  9       1379     0  0x001f  0x4004  0x02c            0     0     -
 10       1378     0  0x0002  0x4004  0x028            0     0     -
 11       1377     0  0x009e  0x4212  0x028            0     -     -
 12       1376     0  0x0020  0x4004  0x02c            0     0     -
 13       1375     0  0x001f  0x4004  0x02c            0     0     -
 14       1374     0  0x0002  0x4004  0x028            0     0     -
 15       1373     0  0x00ae  0x4212  0x028            0     -     -
... (48 entries not shown)
