I want to install the Aurees GUI client on Xubuntu 19.10. Since I can't find a way to install it by repo, I downloaded the .deb file and tried to install it using apt:
# LANG=en_US.utf8 apt install /home/user/Downloads/AureesSetup-linux.deb
Reading package lists... Done
Building dependency tree
Note, selecting 'aureesgit' instead of '/home/user/Downloads/AureesSetup-linux.deb'
aureesgit : PreDepends: libgconf2-4 but it is not installable
PreDepends: libcurl3 but it is not installable
In the classic way using dpkg
# LANG=en_US.utf8 dpkg -i /home/user/Downloads/AureesSetup-linux.deb
dpkg: regarding .../AureesSetup-linux.deb containing aureesgit, pre-dependency problem:
aureesgit pre-depends on gtk-sharp2
gtk-sharp2 is not installed.
dpkg: error processing archive /home/user/Downloads/AureesSetup-linux.deb (--install):
pre-dependency problem - not installing aureesgit
But apt-get install -f doesn't fix the missing dependencies:
# LANG=en_US.utf8 apt-get install -f
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
I also tried to fix the dependency problem by installing it manually:
apt install gtk-sharp2
This changes the error message to another package name, that is missing. So I don't think that this is a reliable way to fix the problem since I'd need to install every dependency manually.
Why is apt using a virtual package aureesgit and not able to resolve the dependencies? I installed other deb packages several times over the years and it worked well before
