How to remove the GobiNet and GobiSerial driver from Ubuntu 16.04? or in general how can I remove any driver from Ubuntu?
Asked
Active
Viewed 797 times
Removing drivers
To remove drivers from memory use:
modprobe -vr GobiSerial
modprobe -vr GobiNet
To prevent drivers from loading in the first place see blacklisting:
Gobiserial specific
If your desire is to fix bad drivers then as per this website you must install firmware updates via Windows, not Linux:
FIRMWARE UPDATE: (Incase you need one)
The firmware update has to be done on windows. Insert the device into a windows box, and let it install drivers and enumerate interafaces. Make sure you can see the managment webpage.
Note the three typos in the original instructions, it's a bad omen....
WinEunuuchs2Unix
- 105,762
