I just installed Popcorn Time following this tutorial.
When I run it as main user (the one who can use sudo privileges) without sudo, it works perfectly.
But when another user tries to run it from his session, this user can't play anything. The program runs normally at the beginning, but then it can't play anything.
When I run it from a Terminal, in both cases (as main user and as simple user), I get the same error code :
$ Popcorn-Time [25376:25376:0117/112038:ERROR:sandbox_linux.cc(345)]
InitializeSandbox() called with multiple threads in process gpu-process.
The main user is in the adm and in the lpadmin groups, the other one isn't. The question is : how give the right to users group to run the program without problem ? In the /opt/ directory there is google-chrome installed and the "simple" user can use it without problem, as the sudo user does.
Thank you, in advance, for your valuable assistance.
