First I did
debian@osboxes:~/Desktop$ mysql -u root -p
Command 'mysql' not found, but can be installed with:
sudo apt install mysql-client-core-8.0     # version 8.0.18-0ubuntu0.19.10.1, or
sudo apt install mariadb-client-core-10.3  # version 1:10.3.20-0ubuntu0.19.10.1
then I installed
debian@osboxes:~/Desktop$ sudo apt install mysql-client-core-8.0
Now I do
Enter password:
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
So now I check
debian@osboxes:~/Desktop$ sudo service mysql status
Unit mysql.service could not be found.
then I do
debian@osboxes:~/Desktop$ ps aux | grep mysql
debian     4379  0.0  0.0   8896   916 pts/0    S+   14:38   0:00 grep --color=auto mysql
so it seems mysql service is running. but when I Try to login now
Enter password:
I also tried.
debian@osboxes:~/Desktop$ systemctl restart mysql
Failed to restart mysql.service: Unit mysql.service not found.
debian@osboxes:~/Desktop$ sudo dpkg -l | grep -E 'mysql'
ii  libmysqlclient21:amd64                     8.0.18-0ubuntu0.19.10.1                 amd64        MySQL database client library
ii  mysql-client-core-8.0                      8.0.18-0ubuntu0.19.10.1                 amd64        MySQL database core client binaries
ii  mysql-common                               5.8+1.0.5ubuntu2                        all          MySQL database common files, e.g. /etc/mysql/my.cnf
Last week I had asked question mysql does not start after a reboot so I know I had installed mysql on this machine in problem. But still I face the problem so tried
debian@osboxes:~/Desktop$ sudo apt-get install mysql-server
E: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 4531 (unattended-upgr) - open (11: Resource temporarily unavailable)
N: Be aware that removing the lock file is not a solution and may break your system.
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), is another process using it?
I also checked
debian@osboxes:~/Desktop$ systemctl -a | grep -iE 'mysql'
there was no output. Also I do
debian@osboxes:~/Desktop$ sudo netstat -tap | grep mysql
sudo: netstat: command not found
then I do
debian@osboxes:~/Desktop$ sudo apt-get install net-tools
No output.
Now based on comments below I did
debian@osboxes:~/Desktop$ sudo rm /var/lib/dpkg/lock
debian@osboxes:~/Desktop$ sudo dpkg --configure -a
debian@osboxes:~/Desktop$ sudo systemctl restart mysql.service
Now try
debian@osboxes:~/Desktop$ sudo rm /var/cache/apt/archives/lock
Now I reboot and then
debian     2403  0.0  0.0   8896   844 pts/0    S+   15:10   0:00 grep --color=auto mysql
Enter password:
It is taking root password which I tried last week. I am not able to understand what should I check. I can't login. What should I check now? I am on Ubuntu 19.10
In addition to mysql client you need to install also mysql server.
I've added info from Ubuntu mysql
Installation
To install MySQL, run the following command from a terminal prompt:
sudo apt install mysql-server
Once the installation is complete, the MySQL server should be started automatically. You can run the following command from a terminal prompt to check whether the MySQL server is running:
When you run this command, you should see the following line or something similar:
tcp        0      0 localhost:mysql         *:*                LISTEN      2556/mysqld
If the server is not running correctly, you can type the following command to start it:
Configuration
You can edit the /etc/mysql/my.cnf file to configure the basic settings -- log file, port number, etc. For example, to configure MySQL to listen for connections from network hosts, change the bind-address directive to the server's IP address:
bind-address            = 192.168.0.5
Replace 192.168.0.5 with the appropriate address.
After making a change to /etc/mysql/my.cnf the MySQL daemon will need to be restarted:
Yaron
  • 13,453
