I installed Ubuntu 19.10 on my MacBook Air and I am not able to connect to the wifi.
I executed the to following command:
jb@jb-MacBookAir:~$ nmcli dev
DEVICE  TYPE      STATE      CONNECTION
lo      loopback  unmanaged  --
jb@jb-MacBookAir:~$ sudo lshw -C network
  *-network
       description: Network controller
       product: BCM4360 802.11ac Wireless Network Adapter
       vendor: Broadcom Inc. and subsidiaries
       physical id: 0
       bus info: pci@0000:03:00.0
       version: 03
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list
       configuration: driver=bcma-pci-bridge latency=0
       resources: irq:18 memory:b0600000-b0607fff memory:b0400000-b05fffff
jb@jb-MacBookAir:~$
So as explained in "How do you get the Broadcom BCM4306 wireless card working?" I installed "b43-fwcutter" and "firmware-b43-installer" by following the following procedure:
"Téléchargez le pilote ici et sauvegardez-le sur un support externe, Copiez l'archive dans votre dossier personnel, Puis dans le dossier /lib/firmware/ avec la commande suivante que vous entrez dans un terminal: sudo cp broadcom-wl-5.100.138.tar.bz2 /lib/firmware/ Déplacez-vous dans le dossier /lib/firmware/ : cd /lib/firmware Décompressez-y votre archive avec les droits d'administration: sudo tar xfvj broadcom-wl-5.100.138.tar.bz2 Nettoyer votre dossier: sudo rm *.bz2 Redémarrez votre ordinateur."
Unfortunatly it didn't work. It is still saying 'No Wi-Fi Adapter Found".
Do you have any idea how to solve this problem ?
Thank you so much!
Jeremy
ubfan1
  • 19,049
Jeremy
For your MBA, you need to install 'broadcom-sta-source' and 'broadcom-sta-dkms'. Remove all b43-* drivers you might have installed as they conflict with your card's drivers (if I remember correctly).
sudo apt install broadcom-sta-source broadcom-sta-dkms
