I have an acer with a Gforce graphics card. I installed ubuntu 11.10 and it was working properly until I installed Nvidia drivers via additional drivers, I hit "nvidia-xconfig" in terminal and then reboot.
At startup lightdm fails to start. I changed /etc/X11/xorg.conf file back to default and reboot. It works properly, but with the default Ubuntu driver.
I want to reconfigure Nvidia and use it. Can anyone tell me what should I do?
coversnail
  • 6,406
That was a mistake to install nvidia drivers on a optimus enabled system.It won't work. First you need to uninstall existing nvidia driver.
  1. Uninstall nvidia, run following in terminal
    sudo nvidia-uninstall
  2. Reinstall the Mesa package for GL:
    sudo apt-get --reinstall install libgl1-mesa-glx
  3. When done, reboot with:
    sudo reboot
To turnoff nvidia graphics card and use it only when required install The Bumblebee:
Add the Stable Bumblebee Releases PPA and install Bumblebee using the proprietary NVIDIA driver:
sudo add-apt-repository ppa:bumblebee/stable
sudo apt-get update
sudo apt-get install bumblebee bumblebee-nvidia
If you have 32-bit applications like Wine, and run 11.10 Oneiric or later, you will need extra libraries:
sudo apt-get install virtualgl-libs:i386
Allow yourself to use Bumblebee by adding yourself to the 'bumblebee' group. (replace $USER by your username)
sudo usermod -a -G bumblebee $USER
Reboot or re-login to apply the group changes
If you'd like to run a program on the nvidia card now, use the optirun program:
optirun firefox &
To test whether it is working, install mesa-utilities by executing sudo apt-get install mesa-utils
  • Run glxgears, wait for sometimes, you will get frame rate every 5 second and it will be like 50-60 fps. It means it is using intel card.
  • run optirun glxgears and see the framerates. It will be much higher indicating nvidia card is working.
  • Also you can run webgl tests with browsers.
Read more from bumblebee wiki
Linked Question:
Is a NVIDIA GeForce with Optimus Technology supported by Ubuntu?
How well will Nvidia Optimus cards be supported in 12.04?
Web-E
  • 21,716
