I was trying to check the authenticity of a download by using the shasum in ubuntu. I am unable to understand the syntax though.
The code below works
  1. echo "<sha-hash> *filename" | shasum -a 256 -c
I wanted to know why are we putting a "*"(asterisk) before the file name.
I also tried generating a file using
  1. shasum -a 256 filename > file.sha
  2. shasum -a 256 -c file.sha
The above code also works. When I opened the file.sha file, I saw
<hash> <filename>
There is no asterisk present in the file. I tried writing the first statement without asterisk, but then it throws an error stating
shasum: standard input: no properly formatted SHA1 checksum lines found
zx485
  • 2,865
Putting an asterisk before the file name tells shasum to treat the file as binary if the system supports this. Id the file should be treated as text file you use a single blank instead.
Linux doesn't make a difference between binary and text files so it doesn't matter which one you use, but you can't leave it out.
So you have to use
<hash>  <filename>
with two blanks after the hash: One blank that separates the hash from the filename and one blank for text mode.
