How to install Java 13 on Ubuntu 18.04.3 from terminal with sudo privildges?
Method 2 For newer Ubuntu (tested in 2025 with Ubuntu 22.04):
sudo apt update
sudo apt upgrade -y
apt search openjdk
#select a version like openjdk-21-jdk or headless if server
# notice the jdk and not jre if you want to compile & build
# headless for jdk without UI non GUi programs; server side, batch, terminal only
sudo apt install openjdk-21-jdk-headless -y
Remove the -y if you want to be prompted
this lists till jdk 21, for newer ones need to use method 1 for now
Method 1: Followed https://openjdk.java.net/install/index.html per Pilot6 comment (thanks).
JDk 22 and later : https://jdk.java.net/23/
JDK 9 to 21
Oracle's OpenJDK JDK binaries for Windows, macOS, and Linux are available on release-specific pages of jdk.java.net as .tar.gz or .zip archives.
As an example, the archives for JDK 13 may be found on jdk.java.net/13 and may be extracted on the command line using
$ tar xvf openjdk-13*_bin.tar.gz
Commands to download java 15 from jdk net (Linux / x64) using terminal and saving to a folder in Downloads folder called 'j'. ~ is shortcut for current logged in user's home directory
mkdir ~/Downloads/j
cd ~/Downloads/j
curl https://download.java.net/java/GA/jdk15.0.2/0d1cfde4252546c6931946de8db48ee2/7/GPL/openjdk-15.0.2_linux-x64_bin.tar.gz --output ./jdk_15.0.2_linuxx64bin.tar.gz
tar xvf j16.tar.gz
Used sudo mv to move directory 'jdk-13.0.1' to /usr/lib/jvm/
sudo mv jdk-13 /usr/lib/jvm/
Then in my ~/.profile file added/edited (as I had Java 11 before) in text editor:
export JAVA_HOME=/usr/lib/jvm/jdk-13.0.1
export PATH=$JAVA_HOME/bin:$PATH
In the current terminal(s) to reload the profile after changes gave command:
. ~/.profile
Note that its a period, a space and then the file name. Its short hand for the command:
source ~/.profile
and could use Java 13. Worked after restart too, without running the commands, due to entry in ~/.profile
To test, in terminal give command :
echo $JAVA_HOME
Will see out put :
You can also set it up as alternatives as in https://askubuntu.com/a/464894/165511 I like to set up the JAVA_HOME variable as need that to run maven etc
sudo update-alternatives --config java
sudo update-alternatives --config javac
Also run
java -version
and
javac -version
To check version of java that is used in that terminal. remember ytou can have different versions in different scripts and programs
- 585
- 1
- 14
- 30
