I was just viewing a diff of configs changed by me and the maintainer's version when I did something wrong with my keyboard because following error occured:
Configuration file '/etc/bind/named.conf.options'
==> File on system created by you or by a script.
==> File also in package provided by package maintainer.
What would you like to do about it ? Your options are:
Y or I : install the package maintainer's version
N or O : keep your currently-installed version
D : show the differences between the versions
Z : start a shell to examine the situation
The default action is to keep your current version.
*** named.conf.options (Y/I/N/O/D/Z) [default=N] ? -- 0:bionic -- time-stamp -- Jan/09/20 11:52:04 --
-- 0:bionic -- time-stamp -- Jan/09/20 11:56:29 --
D
(END)
=== Command terminated with signal 2 (Thu Jan 9 11:57:04 2020) ===
q
Reading cache
q
q^C
Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/apt/cache.py", line 285, in __getitem__
return self._weakref[key]
File "/usr/lib/python3.6/weakref.py", line 137, in __getitem__
o = self.data[key]()
KeyError: 'libcamitk-dev'
During handling of the above exception, another exception occurred:
File "/tmp/ubuntu-release-upgrader-k1z7kgfn/bionic", line 8, in <module>
sys.exit(main())
File "/tmp/ubuntu-release-upgrader-k1z7kgfn/DistUpgrade/DistUpgradeMain.py", line 235, in main
save_system_state(logdir)
File "/tmp/ubuntu-release-upgrader-k1z7kgfn/DistUpgrade/DistUpgradeMain.py", line 128, in save_system_state
scrub_sources=True)
File "/tmp/ubuntu-release-upgrader-k1z7kgfn/DistUpgrade/apt_clone.py", line 149, in save_state
self._write_state_installed_pkgs(sourcedir, tar)
File "/tmp/ubuntu-release-upgrader-k1z7kgfn/DistUpgrade/apt_clone.py", line 190, in _write_state_installed_pkgs
for pkg in cache:
File "/usr/lib/python3/dist-packages/apt/cache.py", line 333, in __iter__
yield self[pkgname]
File "/usr/lib/python3/dist-packages/apt/cache.py", line 288, in __getitem__
rawpkg = self._cache[key]
KeyboardInterrupt
*** Send problem report to the developers?
After the problem report has been sent, please fill out the form in the
automatically opened web browser.
What would you like to do? Your options are:
S: Send report (98.9 KB)
V: View report
K: Keep report file for sending later or copying to somewhere else
I: Cancel and ignore future crashes of this program version
C: Cancel
Please choose (S/V/K/I/C): C
=== Command detached from window (Thu Jan 9 11:57:35 2020) ===
I was trying to reattach to screen, but sudo screen -r says There is no screen to be resumed., and sudo screen -ls says No Sockets found in /run/screen/S-root..
I was looking and found answers about resuming upgrade, but they either apply to cases when only screen was detached or to cases when dpkg exited. But I see dpkg is still running in process list so it may be wiser to continue somehow. Any ideas?
