So far I have run the following commands in terminal. (Ubuntu 18.04 64-bit):
cd ~/Documents/python
sudo apt-get update
sudo apt-get install -y build-essential ccache git zlib1g-dev python2.7 python2.7-dev libncurses5:i386 libstdc++6:i386 zlib1g:i386 openjdk-8-jdk unzip ant ccache autoconf libtool
sudo apt install -y git zip unzip openjdk-8-jdk python3-pip autoconf libtool pkg-config zlib1g-dev libncurses5-dev libncursesw5-dev libtinfo5 cmake libffi-dev
pip3 install --upgrade cython virtualenv
pip3 install --user --upgrade buildozer
buildozer init
But then I get
buildozer: command not found
Why does this not work? I read on a similar question that the problem was resolved due to some dependencies not being installed, but I think I have installed all the dependencies I could find that were recommended.
Thanks
John Doe
  • 133
# add the following line at the end of your ~/.bashrc file
export PATH=$PATH:~/.local/bin/
heynnema
  • 73,649
