Compiling diesel_cli on Ubuntu 16.04, I'm unable to find which package I should install to get rid if the message
~$ cargo install diesel_cli
    Updating crates.io index
  Installing diesel_cli v1.4.0
   Compiling toml v0.4.10
   Compiling diesel_cli v1.4.0
error: linking with `cc` failed: exit code: 1
  = note: "cc" "-Wl,--as-needed"
note: ld: library not found for -lmysqlclient
There was also another dependency, on libpq, but that was solved installing postgresql. Of course I have installed more or less all what I've found related to mysql, indeed the mysql crate installs and execute without problems.
My last attempt have been
sudo apt-get install mysql\*
but the problem is not solved. Any hint ?
CapelliC
  • 285
As the error message noted "library not found for -lmysqlclient" As you probably observed, installing mysql doesn't solve. To resolve it, install libmysqlclient-dev:
sudo apt-get install libmysqlclient-dev
For others encountering a similar issue executing "cargo install diesel_cli", you may also want to add:
sudo apt install libpq-dev
sudo apt install libmariadbclient-dev-compat
sudo apt install libsqlite3-dev
Nditah
  • 146
Thanks to Nditah for
Was getting this error: = note: /usr/bin/ld: cannot find -lpq
Works for postgres now.
Running cargo install diesel_cli --no-default-features --features postgres with no issues now.
Tea Zulo
  • 101
