I am stuck with a (probably) silly problem: modifying preferences in Zotero-standalone! I would like Zotero standalone in Ubuntu to point to the Zotero data in the Windows partition. directory permission The 'Windows data partition' is mounted on a folder of mine. So far Zotero replies that permission to access the directory is denied.
What can I test or correct?
rs@rs-XPS-12-9250:~$ lsblk -o name,partlabel,fstype,mountpoint,UUID
NAME   PARTLABEL                    FSTYPE   MOUNTPOINT                     UUID
loop0                               squashfs /snap/core/8268
loop1                               squashfs /snap/gnome-3-28-1804/110
loop2                               squashfs /snap/chromium/971
loop3                               squashfs /snap/gnome-calculator/406
loop4                               squashfs /snap/gnome-characters/296
loop5                               squashfs /snap/gtk-common-themes/1353
loop6                               squashfs /snap/gnome-logs/61
loop7                               squashfs /snap/gnome-characters/375
loop8                               squashfs /snap/gnome-calculator/544
loop9                               squashfs /snap/canonical-livepatch/90
loop10                              squashfs /snap/core18/1288
loop11                              squashfs /snap/gnome-logs/81
loop12                              squashfs /snap/gnome-system-monitor/100
loop13                              squashfs /snap/libreoffice/163
loop14                              squashfs /snap/core/7270
loop15                              squashfs /snap/gnome-3-28-1804/67
loop16                              squashfs /snap/zotero-snap/4
loop17                              squashfs /snap/gtk-common-themes/1313
loop18                              squashfs /snap/gnome-system-monitor/123
loop19                              squashfs /snap/core18/1066
sda
├─sda1 Basic data partition         ntfs                                    0A9A78FF9A78E899
├─sda2 EFI system partition         vfat     /boot/efi                      9C79-CF74
├─sda3 Microsoft reserved partition
├─sda4 Basic data partition         ntfs     /media/MSW10                   A44E81644E812FDA
├─sda5                              ntfs                                    963A9C573A9C3669
└─sda6                              ext4     /                              2bd5e8dc-7bce-460d-9a54-384a443d97d8
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
To access data stored on a mounted NTFS partition on Ubuntu in Zotero:
  1. Open Ubuntu Software app and find zotero-snap
  2. Click on Permissions
  3. Toggle "Read/write files on removable storage devices" to on
  4. Close and reopen Zotero
Note: The partition is mounted with these permissions/options: ntfs auto,user,rw 0 0
tyknkd
  • 411
OK. You've answered my questions. The point about labeling partitions is that you can see at a glance what partition contains what information. In your example you have 2 NTFS drives both labelled with the same description - Basic data partition, which is confusing. What I suggest is that you label sda4, Win10. Then you know it's your C:\ drive. If sda1 is a recovery drive, label that as WinRec or similar. If you look here you can see I've used proper labels for each partition, not the default ones, so I can see quickly what they all represent.
You can also see that my sda4 is my data partition where all data files and folders are shared between Ubuntu and Windows. I keep all data separately from the system partitions, so that a) If I ever need to reinstall Windows the data isn't affected. b) I now can reference the data partition directly from Ubuntu without the need to load my Windows system as well. c) I now mount sda4 at boot-up so that no permission problems arise as I can now make my own permissions in the /etc/fstab file.
To return to your original question I would suggest you do similar, ie make a new partition, format it NTFS, label it 'Data' and move all data folders and files (not just Zotero) from your C:\ drive to the new partition. Once you've done that I'll tell you how to proceed from there.
Paul Benson
  • 1,041
