So Preview for Mac OS X has this capability. I want to be able to just highlight whatever on a pdf, and be able to copy and paste immediately into another pdf file (via the clipboard).
I do a lot in LaTeX, and this would really make things easier why TeXing in ubuntu/linux.
Ringtail
  • 16,285
efang
  • 69
uPDF is an editor tool to write and paint to an existing pdf file. uPdf can insert pages of another pdf, insert new pages, remove and extract pages, rotate pages, paste a text or an image in the existing pdf, and much more.
You can install it in Ubuntu using ppa. For the moment, as I checked on https://launchpad.net/~atareao/+archive/updf, the uPDF ppa supports only Ubuntu 12.10 and 12.04. To install it, open a terminal and run next commands:
sudo add-apt-repository ppa:atareao/updf
sudo apt-get update
sudo apt-get install gir1.2-rsvg-2.0 updf
If you use KDE you may also need to install the following dependency:
sudo apt-get install-0.1 gir1.2-appindicator3
More info: Install uPDF (effective pdf editor) in Ubuntu 12.04 /12.10
Another tool for editing pdf files and that can be found in Ubuntu Software Center is Master PDF Editor Install comixcursors-lefthanded - a complete solution for view, print and edit PDF and XPS files.
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
Try PDF Mod:
PDF Mod is a simple application for modifying PDF documents.
You can reorder, rotate, and remove pages, export images from a document, edit the title, subject, author, and keywords, and combine documents via drag and drop.
sudo apt-get install pdfmod
Or PDF-Shuffler:
PDF-Shuffler is a small python-gtk application, which helps the user to merge or split pdf documents and rotate, crop and rearrange their pages using an interactive and intuitive graphical interface. It is a frontend for python-pyPdf.
sudo apt-get install pdfshuffler
See also:
landroni
  • 6,011
This was my question as well, since I used this functionality in Mac Preview a lot.
The best solution I found in Ubuntu is to use PDF Master Editor (the free version will do).
You can select a range and copy it, open a blank .pdf file with Ctrl+N and paste the selection there. If you don't like the white margins, you can then crop using Document => Crop menu (Ctrl+K).
Unrelated to your question, this application is also great for annotating and highlighting in Linux (which is missing from many common Linux PDF-viewers).
Videonauth
  • 33,815
