I wanted to install Ubuntu with dual-boot but the installer couldn't find the windows partition.
I read online that erasing the GPT could help. I did so with gdisk (wich told me that I have MBR protective and GPT present). After that I cannot load windows and Ubuntu still tell me that windows is not installed.
When I try to boot, I get a message from the motherboard that says "Default boot device missing or boot failed".
gdisk now say that I have MBR protective and no GPT.
I tried all the boot list, nothing works.
I'm scared I cannot recover my data... :/
"MBR Protective" is a part of the GPT, but since you've deleted the GPT partitioning, you will need to reinstall then restore from your last backup.
K7AAY
  • 17,705
You should be able to recover partitions. You need to turn off "legacy boot" in your BIOS. (you should have done this before installing; then you would not have had your problems). By allowing only UEFI boot, the Ubuntu live disk will boot in this mode.
EDIT: Your bios is not guaranteed to call it 'legacy boot'. You want to allow only EFI/UEFI boot (they mean the same thing). Legacy boot is sometimes called CSM. Learn more: Difference between Legacy BIOS and UEFI )
Then, try this: https://ubuntuforums.org/showthread.php?t=370121
Be very careful deleting partitions or partition tables. It's worth while researching what you are about to do, rather than trusting advice, or misunderstanding it. Or ask here.
