A little background before I go into the main problem - I have windows installed in a 256GB nvme ssd that came with the laptop. Then I added a 2.5" SSD manually (Samsung Evo 860) for additional space and installing Ubuntu 16.04 in it. I need 16.04 for work so can't go for higher versions. The ssd is detected in windows and I was even able to store files in it.
So then I tried dual booting my system with windows 10 and Ubuntu 16.04, while windows running in the nvme and linux in the 2.5" ssd. I made a bootable usb device with rufus, then shrunk the volume of the ssd which I wanted to install linux in by 100GB using Gparted. Then when I tried the install Ubuntu option I got the following error Force UEFI Installation? with following error message
This machine's firmware has started this installer in UEFI mode but it looks like there maybe existing operating systems already installed using BIOS compatibility mode, If you continue to install Debian in UEFI mode,it might be difficult to reboot into any BIOS-mode operating system.
But the BIOS mode of my laptop is UEFI and no other OS other than windows is installed. Windows 10 came with the laptop, so I assume they must have installed it UEFI mode, since as far as my understanding goes the newer laptops don't use legacy mode anymore. And also I confirmed this with the MSinfo32.
So coming back to the error, I clicked on the continue in UEFI mode , which lead me to the partitioning window, where I chose Something else (NOTE: during the previous times when I dual booted, I usually see an option called Install ubuntu along with windows, but I couldn't see it this time and I assumed it is because I am installing in a separate hard drive other than the one in which windows was installed). So I allocated 20 GB for root, 8 GB for swap and rest for home.( I did this with Use as ext4 and during my first time of installation I gave the type for the new parition as primary and when this failed I tried again with logical, but still no luck) So the partitioning went well then during half of the installation process I got the error GRUB installation failed and the following error message
The 'grub-efi-amd64-signed' package failed to install into /target/. Without the GRUB boot loader, the installed system will not boot
And when I pressed ok, the installation process quit. I don't know what to do after this. Is this happening because of trying to dual boot in two seperate ssds? Could someone please help me with this?
HariP19
  • 41
When trying to install Ubuntu on a computer that had two SSDs I got an error message similar to:
Without the GRUB boot loader, the installed system will not boot.
iirc it was the same error message exactly.
Follow these steps.
  1. Install Ubuntu in UEFI mode anyway because if the OSs are installed in different modes, dual booting Windows and Ubuntu often can't work. This way both Windows and Ubuntu will be installed in UEFI mode, and you should have less problems.
  2. Ignore the 'grub-efi-amd64-signed' package failed to install into /target/ error message.
  3. Restart the computer at the end of the unsuccessful Ubuntu installation and boot from a Boot-Repair live USB. Select the Recommended repair option in Boot-Repair, run it, and restart the computer. The recommended repair will take a minute or two to finish.
  4. Boot from the Ubuntu live USB again. This time the Ubuntu installer will detect a dual boot system with Windows 10 alongside what it calls "generic Linux". This "generic Linux" is really Ubuntu with a different bootloader which was installed by Boot-Repair. Select the option at the Installation type screen to Erase generic Linux and install Ubuntu.
  5. Install Ubuntu on the entire disk. Make sure that you select the right disk, so you don't overwrite Windows. If you want you can make another data storage partition on the SSD, but Windows 10 already has 256GB on the NVMe SSD which is enough disk space for Windows.
  6. Let the Ubuntu installation run successfully until the end, including installing the grub bootloader.
  7. Boot the computer again and enter the UEFI setup utility. Change the boot order in the UEFI so that the SSD on which Ubuntu is installed boots first in the boot priority sequence. Usually the boot priority sequence is found under the Boot tab. If you skip this step, then the computer will boot using the existing Windows 10 bootloader which is still installed on the NVMe SSD instead of booting to the GRUB boot menu. The GRUB menu will allow you to choose either Windows 10 or Ubuntu when you boot the computer.
When you reboot the computer into Ubuntu for the first time, open the Disks application and check the partitioning of the SSD. There may be a 500MB FAT EFI System partition located at the beginning of the SSD, an ext4 partition and a swap partition. Ubuntu 16.04 is the last Ubuntu LTS release that creates a swap partition by default on new installations. New installations of Ubuntu 17.04 and later create a swap file by default instead of a swap partition.
karel
  • 122,292
  • 133
  • 301
  • 332
