Is there any way to always save the content of whatever is happening on terminal window to a file?
I want to save each and every command that is being executed and its output to a file to keep track of change history and I want to enable it up permanently on terminal.
Any suggestions pls?
script,from the bsdutils package is the tool you want.
script my.log
# bunch of commands
exit
and all the commands you typed, and all their output (including cursor control, which depends of the setting of $TERM) will be saved in my.log.
From the man page:
bionic (1) script.1.gz
Provided by: bsdutils_2.31.1-0.4ubuntu3_amd64 bug
NAME
       script - make typescript of terminal session
SYNOPSIS
       script [options] [file]
DESCRIPTION
       script  makes  a  typescript  of  everything displayed on your terminal.  It is useful for
       students who need a hardcopy record of an interactive session as proof of  an  assignment,
       as the typescript file can be printed out later with lpr(1).
       If  the argument file is given, script saves the dialogue in this file.  If no filename is
       given, the dialogue is saved in the file typescript.
waltinator
  • 37,856
You can use this for appending to a file without overwriting.
your_command >>/path/to/file
You can also check .bash_history for the order of commands.
This answer might help.
Sharan
  • 121
