I have Ubuntu (latest version) installed on a Toshiba laptop which has UEFI, and need to update the BIOS.
Toshiba provides BIOS updates as EXE files. I do not have Windows as dual boot, so I tried to create a live USB with freedos installed and boot from that, to then run the EXE file. I have tried multiple times now using multiple methods, and the USB drive will not boot. I even tried to create a live USB with Win10 and that failed also. The USB drives boots just fine on another laptop that does not use UEFI, but not on the laptop that does. So I presume that the USB drive is not being set up correctly to be recognised as bootable on the Toshiba UEFI laptop?
This question is linked to an earlier question (EXT4-fs error on Toshiba Tecra with WD SSD) so you can see the methods I tried (with thanks to @heynnema). These include using UNetbootin and mkusb.
Any help would be much appreciated as I really need to update the BIOS.
You can try toggling the UEFI setting on your BIOS. Keeping in mind when you update the BIOS, you may have to change the UEFI settings again.
Crabtree
  • 181
