I'm trying to build a JFX app on IntelliJ. I installed JavaFX using the command:
sudo apt-get install openjfx
I found somewhere that I am supposed to add jfxswt.jar and jfxrt.jar to the class path. I ran the find command on the root directory but I didn't find either file.
EDIT:
apt policy openjfx output:
openjfx:
  Installed: 11.0.2+1-1~18.04.2
  Candidate: 11.0.2+1-1~18.04.2
  Version table:
 *** 11.0.2+1-1~18.04.2 500
        500 http://jo.archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages
        500 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 Packages
        100 /var/lib/dpkg/status
     8u161-b12-1ubuntu2 500
        500 http://jo.archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
Edit 2:
dpkg -L openjfx output:
/usr
/usr/share
/usr/share/doc
/usr/share/doc/openjfx
/usr/share/doc/openjfx/TODO.Debian
/usr/share/doc/openjfx/changelog.Debian.gz
/usr/share/doc/openjfx/copyright
/usr/share/openjfx
/usr/share/openjfx/lib
/usr/share/openjfx/lib/javafx.properties
/usr/share/openjfx/lib/javafx.base.jar
/usr/share/openjfx/lib/javafx.controls.jar
/usr/share/openjfx/lib/javafx.fxml.jar
/usr/share/openjfx/lib/javafx.graphics.jar
/usr/share/openjfx/lib/javafx.media.jar
/usr/share/openjfx/lib/javafx.swing.jar
/usr/share/openjfx/lib/javafx.web.jar
Edit 3:
ls /usr/lib/jvm/java-8-openjdk-amd64/jre/lib/ output:
accessibility.properties  ext                                jvm.hprof.txt         resources.jar
amd64                     flavormap.properties               logging.properties    rt.jar
calendars.properties      hijrah-config-umalqura.properties  management            security
charsets.jar              images                             management-agent.jar  sound.properties
classlist                 jar.binfmt                         meta-index            swing.properties
cmm                       jce.jar                            net.properties        tzdb.dat
content-types.properties  jexec                              psfontj2d.properties
currency.data             jsse.jar                           psfont.properties.ja
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
Jim
I'm not sure how but it finally installed. Here's the link to the answer that I found:
Openjfx is not installing
The answer is the one by laurenmurphyx64. Here are the commands that I used:
apt purge openjfx
apt install openjfx=8u161-b12-1ubuntu2 libopenjfx-jni=8u161-b12-1ubuntu2 libopenjfx-java=8u161-b12-1ubuntu2
apt-mark hold openjfx libopenjfx-jni libopenjfx-java
Jim
