Laptop: Acer Predator PH315-52
OS : UBUNTU 18.04.2 LTS
Nvidia Driver : 418.87
Kernel : 5.0.0-37-generic
Processors : Intel UHD 630 and Nvidia 1660 Ti
bbswitch version: 0.8-4ubuntu1
bumblebee version: 3.2.1+git20181231-103~bionicppa1
$ grep bumblebeed /var/log/syslog
Output:
Predator bumblebeed[3353]: Received Terminated signal.
Predator bumblebeed[3353]: Unable to disable discrete card.
Predator bumblebeed[7981]: /usr/sbin/bumblebeed started
Predator bumblebeed[7981]: Unable to disable discrete card.
$ lsmod | grep -i nouveau
Output: (Blank output) ## showing nouveau is not loaded
$ lsmod | grep nvidia
Output:
i2c_nvidia_gpu ## Handled it via "$ modprobe -r i2c_nvidia_gpu" but the problem still remains ## and the outputs of all too remains the same ## Blank output of "lsmod | grep nvidia" after unloading it using ablove command
$ cat /proc/acpi/bbswitch
Ouput:0000:01:00.0 ON
$ sudo tee /proc/acpi/bbswitch <<<**OFF**
Output:OFF
$ dmesg | grep bbswitch
[ 6.659422] bbswitch: loading out-of-tree module taints kernel.
[ 6.660407] bbswitch: module verification failed: signature and/or required key missing - tainting kernel
[ 6.661578] bbswitch: version 0.8
[ 6.662580] bbswitch: Found integrated VGA device 0000:00:02.0: \_SB_.PCI0.GFX0
[ 6.663575] bbswitch: Found discrete VGA device 0000:01:00.0: \_SB_.PCI0.PEG0.PEGP
[ 6.665690] bbswitch: detected an Optimus _DSM function
[ 6.667873] bbswitch: Succesfully loaded. Discrete card 0000:01:00.0 is on
[ 18.818552] bbswitch: disabling discrete graphics
[ 114.697607] bbswitch: disabling discrete graphics
[ 114.697852] acpi_thermal_rel intel_pch_thermal wmi_bmof acer_wmi
acer_wireless intel_lpss mac_hid soundcore sparse_keymap acpi_pad sch_fq_codel parport_pc ppdev lp parport bbswitch(OE) ip_tables x_tables autofs4 hid_generic usbhid i915 kvmgt vfio_mdev mdev vfio_iommu_type1 vfio kvm irqbypass i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops drm alx ahci mdio i2c_hid libahci i2c_nvidia_gpu hid wmi video pinctrl_cannonlake pinctrl_intel
[ 114.697897] bbswitch_off+0xbb/0x230 [bbswitch]
[ 114.697898] bbswitch_proc_write+0xb5/0xcc [bbswitch]
[ 446.444365] bbswitch: disabling discrete graphics
Ouput:0000:01:00.0 ON #############This is the problem,it should display OFF
$ optirun --status
Output: Bumblebee status: Ready (). X inactive. Discrete video card is on.
Also video LNXVIDEO:00: Failed to change power state to D3hot
Installation steps taken:
$ sudo apt update
Installed Cuda 10.1 .deb package from nvidia website and driver 418.87 was automatically   installed with the package(also prime-select was also installed with it)
$ sudo nano /etc/default/grub
changed - GRUB_CMDLINE_LINUX_DEFAULT='pcie_port_pm=off acpi_backlight=none acpi_osi=Linux acpi_osi=! acpi_osi=\"Windows 2009\"'
$ sudo add-apt-repository ppa:bumblebee/testing
$ sudo apt update
Installed synaptics package manager and then through it installed bumblebee,bumblebee-nvidia   and primus(and all others which by default get installed with them like bbswitch)
$ sudo nano /etc/bumblebee/bumblebee.conf
 Changed 'Driver=' to 'Driver=nvidia'
  Bridge=primus
  KernelDriver=nvidia
  PMMethod=bbswitch
  LibraryPath=/usr/lib/x86_64-linux-gnu:/usr/lib/i386-linux-gnu
  XorgModulePath=/usr/lib/x86_64-linux-gnu/xorg,/usr/lib/xorg/modules
  XorgConfFile=/etc/bumblebee/xorg.conf.nvidia
$ sudo nano /etc/modprobe.d/bumblebee.conf
 blacklist nvidia
  blacklist nvidia-current
  blacklist nvidia-current-updates
  blacklist nvidia_drm
  blacklist nvidia_uvm
  blacklist nvidia_modeset
  blacklist nvidiafb
  blacklist i2c-nvidia-gpu
  blacklist nouveau
$ sudo nano /etc/modules-load.d/modules.conf
added following:
   i915
   bbswitch
selected intel as prime profile
Restarted laptop and the above stated problems kicked in.
Also upon startup grep bumblebeed /var/log/syslog shows- Predator bumblebeed[864]: /usr/sbin/bumblebeed started Predator bumblebeed[864]: Unable to disable discrete card.
Please help me solve the problem.
I have exactly the same problem, on an msi laptop (GS65 stealth).
I just looked at the lsmod output and tried removing the module manually as well, right now. I'd bump your post but i just created this account.
Using the nvidia card on adaptive power mode at least saves you more battery (lasts about twice as much).
EDIT: Disabling or blacklisting the i2c_nvidia_gpu module wont do anything. This module loads by default even when you don't have the nouveau or nvidia drivers installed, it has nothing to do with bumblebee/bbswitch apparently.
Bumblebee/prime are working correctly at first glance, the nvidia drivers are being deactivated and you're working with the intel integrated graphics, the problem seems to be that somehow, the nvidia GPU is still dragging a lot of power from the computer even when it is not in use (and should be OFF).
EDIT 2:
I found this other post regarding powering off the dedicated gpu, maybe this can work for you. I'll try it later:
https://www.reddit.com/r/linux/comments/78is1r/complete_disable_of_discrete_gpu/
EDIT3: For me, selecting the Intel prime profile from the nvidia xserver settings (or prime-select intel), logging out then back in, and running
manually works.
Are you sure nouveau is completely blacklisted? I had to add balcklist=nouveau to the GRUB_CMDLINE_LINUX_DEFAULT options in /etc/default/grub, and run update-grub, since the blacklist.conf file didn't seem to work.
