I cannot make ubuntu 16.06 LTS recognize my new Wacom One device. It is actually recognized from usb.
>> lsusb
>> Bus 001 Device 003: ID 056a:037b Wacom Co., Ltd
However in the system settings > hardware > wacom tablet, there is no tablet detected.
I have also tried install xserver-xorg-input-wacom but I have some dependency problems.
Reading package lists... Done
Building dependency tree
xserver-xorg-input-wacom : Depends: xorg-input-abi-22
Depends: xserver-xorg-core (>= 2:1.17.99.902)
I tried to install those dependencies manually but I was not sure if I was doing right due to the warning about the removing of some serious other packages.
sudo apt-get install xserver-xorg-core
The following packages were automatically installed and are no longer required:
libxfont2 xserver-xorg-legacy-hwe-16.04
Use 'sudo apt autoremove' to remove them.
Suggested packages:
xfonts-100dpi | xfonts-75dpi
The following packages will be REMOVED:
ubuntu-desktop xorg xserver-xorg-core-hwe-16.04 xserver-xorg-hwe-16.04
xserver-xorg-input-all-hwe-16.04 xserver-xorg-input-evdev-hwe-16.04
xserver-xorg-input-synaptics-hwe-16.04
xserver-xorg-input-wacom-hwe-16.04 xserver-xorg-video-all-hwe-16.04
xserver-xorg-video-amdgpu-hwe-16.04 xserver-xorg-video-ati-hwe-16.04
xserver-xorg-video-fbdev-hwe-16.04 xserver-xorg-video-intel-hwe-16.04
xserver-xorg-video-nouveau-hwe-16.04 xserver-xorg-video-qxl-hwe-16.04
xserver-xorg-video-radeon-hwe-16.04 xserver-xorg-video-vesa-hwe-16.04
xserver-xorg-video-vmware-hwe-16.04
The following NEW packages will be installed:
xserver-xorg-core
0 upgraded, 1 newly installed, 18 to remove and 0 not upgraded.
Need to get 1 344 kB of archives.
After this operation, 5 702 kB disk space will be freed.
Do you want to continue? [Y/n]
So, I am stuck here. Any suggestion?
Update: I have solved detection issue by following this link. I still find it quite hassle. It would be so nice to have a ppa but, well, it works now so here is my steps:
- Downloaded input-wacom-0.45.0.tar.bz2 .
Extracted into a folder and computed:
if test -x ./autogen.sh; then ./autogen.sh; else ./configure; fi && make && sudo make install || echo "Build Failed"
However, still I can't make the system detect the tabled as xinput properly. I don't have pressure sensitivity although my device is in the list of xinputs.
>> xinput list
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ Melfas LGDisplay Incell Touch id=12 [slave pointer (2)]
⎜ ↳ DELL0818:00 044E:121F Mouse id=13 [slave pointer (2)]
⎜ ↳ DELL0818:00 044E:121F Touchpad id=14 [slave pointer (2)]
⎜ ↳ Wacom One by Wacom M Pen stylus id=21 [slave pointer (2)]
⎜ ↳ Wacom One by Wacom M Pen eraser id=22 [slave pointer (2)]
I have computed as it is stated in the link:
sudo sh -c "apt-get update && apt-get install xserver-xorg-input-wacom$(dpkg -S $(which Xorg) | grep -Eo -- "-hwe-[^:]*")"
which gives me xserver-xorg-input-wacom-hwe-16.04 is already the newest version (1:0.34.0-0ubuntu2~16.04.1).
Now I am still stuck in pressure sensitivity.
