I installed Ubuntu a month ago, then decided to reinstall Windows 10. I tried copying files from ISO to a FAT32 formatted USB flash drive, making this with woeusb and unetbootin, adding flags. After making the Windows bootable USB with unetbootin, the USB flash drive starts, but the bootloader don't see windows files/gives only default option.
Asked
Active
Viewed 2,471 times
If your pc is UEFI, you should:
Create
NTFSfilesystem on USB's first (and single) partition,Set the partition type to 'Microsoft Basic Data`
Copy all files from ISO to USB
Reboot, enter boot menu and select USB's first partition to boot into
People usually make mistake of creating FAT32 filesystem, but in most cases it does not work since windows ISO include a bigger file than the size supported by FAT32
If your pc is not UEFI, you should use WoeUSB tool to create bootable `Windows Pendrive'
Ahmad Raza
- 86
