$ apt install php
Reading package lists... Done
Building dependency tree
php is already the newest version (2:7.4+71+ubuntu19.04.1+deb.sury.org+1).
The following packages were automatically installed and are no longer required:
libapache2-mod-php7.3 php7.3 php7.3-bz2
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
42 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up php7.2-common (7.2.26-1+ubuntu19.04.1+deb.sury.org+1) ...
dpkg: error processing package php7.2-common (--configure):
installed php7.2-common package post-installation script subprocess returned error exit status 10
dpkg: dependency problems prevent configuration of php7.2-opcache:
php7.2-opcache depends on php7.2-common (= 7.2.26-1+ubuntu19.04.1+deb.sury.org+1); however:
Package php7.2-common is not configured yet.
dpkg: error processing package php7.2-opcache (--configure):
dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
Setting up php5.6-common (5.6.40-15+ubuntu19.04.1+deb.sury.org+1) ...
dpkg: error processing package php5.6-common (--configure):
installed php5.6-common package post-installation script subprocess returned error exit status 10
dpkg: dependency problems prevent configuration of php7.2-cli:
php7.2-cli depends on php7.2-common (= 7.2.26-1+ubuntu19.04.1+deb.sury.org+1); however:
php7.2-cli depends on php7.2-opcache; however:
Package php7.2-opcache is not configured yet.
dpkg: error processing package php7.2-cli (--configure):
No apport report written because MaxReports is reached already
Setting up php7.0-common (7.0.33-13+ubuntu19.04.1+deb.sury.org+1) ...
dpkg: error processing package php7.0-common (--configure):
installed php7.0-common package post-installation script subprocess returned error exit status 10
Setting up php7.4-common (7.4.1-1+ubuntu19.04.1+deb.sury.org+1) ...
dpkg: error processing package php7.4-common (--configure):
installed php7.4-common package post-installation script subprocess returned error exit status 10
dpkg: dependency problems prevent configuration of php7.0-cli:
php7.0-cli depends on php7.0-common (= 7.0.33-13+ubuntu19.04.1+deb.sury.org+1); however:
Package php7.0-common is not configured yet.
dpkg: error processing package php7.0-cli (--configure):
dpkg: dependency problems prevent configuration of php7.2:
php7.2 depends on php7.2-common; however:
dpkg: error processing package php7.2 (--configure):
dpkg: dependency problems prevent configuration of php5.6-bz2:
php5.6-bz2 depends on php5.6-common (= 5.6.40-15+ubuntu19.04.1+deb.sury.org+1); however:
Package php5.6-common is not configured yet.
dpkg: error processing package php5.6-bz2 (--configure):
dpkg: dependency problems prevent configuration of php7.0:
php7.0 depends on php7.0-common; however:
dpkg: error processing package php7.0 (--configure):
dpkg: dependency problems prevent configuration of php7.4-readline:
php7.4-readline depends on php7.4-common (= 7.4.1-1+ubuntu19.04.1+deb.sury.org+1); however:
Package php7.4-common is not configured yet.
dpkg: error processing package php7.4-readline (--configure):
dpkg: dependency problems prevent configuration of php7.0-readline:
php7.0-readline depends on php7.0-common (= 7.0.33-13+ubuntu19.04.1+deb.sury.org+1); however:
dpkg: error processing package php7.0-readline (--configure):
dpkg: dependency problems prevent configuration of php7.4-bz2:
php7.4-bz2 depends on php7.4-common (= 7.4.1-1+ubuntu19.04.1+deb.sury.org+1); however:
dpkg: error processing package php7.4-bz2 (--configure):
dpkg: dependency problems prevent configuration of php7.4-cli:
php7.4-cli depends on php7.4-common (= 7.4.1-1+ubuntu19.04.1+deb.sury.org+1); however:
php7.4-cli depends on php7.4-readline; however:
Package php7.4-readline is not configured yet.
dpkg: error processing package php7.4-cli (--configure):
dpkg: dependency problems prevent configuration of libapache2-mod-php7.2:
libapache2-mod-php7.2 depends on php7.2-cli; however:
Package php7.2-cli is not configured yet.
libapache2-mod-php7.2 depends on php7.2-common (= 7.2.26-1+ubuntu19.04.1+deb.sury.org+1); however:
libapache2-mod-php7.2 depends on php7.2-opcache; however:
dpkg: error processing package libapache2-mod-php7.2 (--configure):
Setting up unattended-upgrades (1.10ubuntu5.2) ...
dpkg: error processing package unattended-upgrades (--configure):
installed unattended-upgrades package post-installation script subprocess returned error exit status 10
dpkg: dependency problems prevent configuration of php7.0-json:
php7.0-json depends on php7.0-common (= 7.0.33-13+ubuntu19.04.1+deb.sury.org+1); however:
dpkg: error processing package php7.0-json (--configure):
Setting up php7.3-common (7.3.13-1+ubuntu19.04.1+deb.sury.org+1) ...
dpkg: error processing package php7.3-common (--configure):
installed php7.3-common package post-installation script subprocess returned error exit status 10
dpkg: dependency problems prevent configuration of php7.2-json:
php7.2-json depends on php7.2-common (= 7.2.26-1+ubuntu19.04.1+deb.sury.org+1); however:
dpkg: error processing package php7.2-json (--configure):
dpkg: dependency problems prevent configuration of php7.4:
php7.4 depends on php7.4-common; however:
dpkg: error processing package php7.4 (--configure):
dpkg: dependency problems prevent configuration of php7.3-xml:
php7.3-xml depends on php7.3-common (= 7.3.13-1+ubuntu19.04.1+deb.sury.org+1); however:
Package php7.3-common is not configured yet.
dpkg: error processing package php7.3-xml (--configure):
dpkg: dependency problems prevent configuration of php7.0-mysql:
php7.0-mysql depends on php7.0-No apport report written because MaxReports is reached already
dpkg: error processing package php7.0-mysql (--configure):
dpkg: dependency problems prevent configuration of php7.3-cli:
php7.3-cli depends on php7.3-common (= 7.3.13-1+ubuntu19.04.1+deb.sury.org+1); however:
dpkg: error processing package php7.3-cli (--configure):
dpkg: dependency problems prevent configuration of php7.3-opcache:
php7.3-opcache depends on php7.3-common (= 7.3.13-1+ubuntu19.04.1+deb.sury.org+1); however:
dpkg: error processing package php7.3-opcache (--configure):
dpkg: dependency problems prevent configuration of php7.4-opcache:
php7.4-opcache depends on php7.4-common (= 7.4.1-1+ubuntu19.04.1+deb.sury.org+1); however:
dpkg: error processing package php7.4-opcache (--configure):
dpkg: dependency problems prevent configuration of php7.0-fpm:
php7.0-fpm depends on php7.0-cli; however:
Package php7.0-cli is not configured yet.
php7.0-fpm depends on php7.0-common (= 7.0.33-13+ubuntu19.04.1+deb.sury.org+1); however:
php7.0-fpm depends on php7.0-json; however:
Package php7.0-json is not configured yet.
dpkg: error processing package php7.0-fpm (--configure):
Setting up openafs-client (1.8.2-1ubuntu0.1) ...
Job for openafs-client.service failed because the control process exited with error code.
See "systemctl status openafs-client.service" and "journalctl -xe" for details.
invoke-rc.d: initscript openafs-client, action "start" failed.
● openafs-client.service - OpenAFS client
Loaded: loaded (/lib/systemd/system/openafs-client.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Thu 2019-12-26 19:51:34 IST; 13ms ago
Process: 7313 ExecStartPre=/usr/share/openafs/openafs-client-precheck (code=exited, status=0/SUCCESS)
Process: 7331 ExecStart=/sbin/afsd $AFSD_ARGS (code=exited, status=1/FAILURE)
Process: 7333 ExecStopPost=/sbin/rmmod $KMOD (code=exited, status=0/SUCCESS)
Dec 26 19:51:34 Vachher systemd[1]: Starting OpenAFS client...
Dec 26 19:51:34 Vachher afsd[7331]: afsd: some file missing or bad in /etc/openafs/
Dec 26 19:51:34 Vachher systemd[1]: openafs-client.service: Control process exited, code=exited, status=1/FAILURE
Dec 26 19:51:34 Vachher systemd[1]: openafs-client.service: Failed with result 'exit-code'.
Dec 26 19:51:34 Vachher systemd[1]: Failed to start OpenAFS client.
dpkg: error processing package openafs-client (--configure):
installed openafs-client package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of php7.2-readline:
php7.2-readline depends on php7.2-common (= 7.2.26-1+ubuntu19.04.1+deb.sury.org+1); however:
dpkg: error processing package php7.2-readline (--configure):
dpkg: dependency problems prevent configuration of php7.0-opcache:
php7.0-opcache depends on php7.0-common (= 7.0.33-13+ubuntu19.04.1+deb.sury.org+1); however:
dpkg: error processing package php7.0-opcache (--configure):
dpkg: dependency problems prevent configuration of libapache2-mod-php7.4:
libapache2-mod-php7.4 depends on php7.4-cli; however:
Package php7.4-cli is not configured yet.
libapache2-mod-php7.4 depends on php7.4-common (= 7.4.1-1+ubuntu19.04.1+deb.sury.org+1); however:
libapache2-mod-php7.4 depends on php7.4-opcache; however:
Package php7.4-opcache is not configured yet.
dpkg: error processing package libapache2-mod-php7.4 (--configure):
dpkg: dependency problems prevent configuration of php:No apport report written because MaxReports is reached already
php depends on php7.4; however:
Package php7.4 is not configured yet.
dpkg: error processing package php (--configure):
dpkg: dependency problems prevent configuration of php-pear:
php-pear depends on php-cli; however:
Package php-cli is not installed.
Package php7.4-cli which provides php-cli is not configured yet.
Package php7.3-cli which provides php-cli is not configured yet.
Package php7.2-cli which provides php-cli is not configured yet.
Package php7.0-cli which provides php-cli is not configured yet.
dpkg: error processing package php-pear (--configure):
dpkg: dependency problems prevent configuration of php7.4-json:
php7.4-json depends on php7.4-common (= 7.4.1-1+ubuntu19.04.1+deb.sury.org+1); however:
dpkg: error processing package php7.4-json (--configure):
dpkg: dependency problems prevent configuration of php7.4-xml:No apport report written because MaxReports is reached already
php7.4-xml depends on php7.4-common (= 7.4.1-1+ubuntu19.04.1+deb.sury.org+1); however:
dpkg: error processing package php7.4-xml (--configure):
dpkg: dependency problems prevent configuration of php7.3-json:No apport report written because MaxReports is reached already
php7.3-json depends on php7.3-common (= 7.3.13-1+ubuntu19.04.1+deb.sury.org+1); however:
dpkg: error processing package php7.3-json (--configure):
dpkg: dependency problems prevent configuration of php7.3-readline:
php7.3-readline depends on php7.3-common (= 7.3.13-1+ubuntu19.04.1+deb.sury.org+1); however:
dpkg: error processing package php7.3-readline (--configure):
dpkg: dependency problems prevent configuration of php-bz2:
php-bz2 depends on php7.4-bz2; however:
Package php7.4-bz2 is not configured yet.
dpkg: error processing package php-bz2 (--configure):
dpkg: dependency problems prevent configuration of php7.3:
php7.3 depends on php7.3-common; however:
dpkg: error processing package php7.3 (--configure):
dpkg: dependency problems prevent configuration of libapache2-mod-php7.3:
libapache2-mod-php7.3 depends on php7.3-cli; however:
Package php7.3-cli is not configured yet.
libapache2-mod-php7.3 depends on php7.3-common (= 7.3.13-1+ubuntu19.04.1+deb.sury.org+1); however:
libapache2-mod-php7.3 depends on php7.3-json; however:
Package php7.3-json is not configured yet.
libapache2-mod-php7.3 depends on php7.3-opcache; however:
Package php7.3-opcache is not configured yet.
dpkg: error processing package libapache2-mod-php7.3 (--configure):
dpkg: dependency problems prevent configuration of php7.3-bz2:
php7.3-bz2 depends on php7.3-common (= 7.3.13-1+ubuntu19.04.1+deb.sury.org+1); however:
dpkg: error processing package php7.3-bz2 (--configure):
dpkg: dependency problems prevent configuration of libapache2-mod-php:
libapache2-mod-php depends on libapache2-mod-php7.4; however:
Package libapache2-mod-php7.4 is not configured yet.
dpkg: error processing package libapache2-mod-php (--configure):
dpkg: dependency problems prevent configuration of php-xml:
php-xml depends on php7.4-xml; however:
Package php7.4-xml is not configured yet.
dpkg: error processing package php-xml (--configure):
php7.2-common
php7.2-opcache
php5.6-common
php7.2-cli
php7.0-common
php7.4-common
php7.0-cli
php7.2
php5.6-bz2
php7.0
php7.4-readline
php7.0-readline
php7.4-bz2
php7.4-cli
unattended-upgrades
php7.0-json
php7.3-common
php7.2-json
php7.4
php7.3-xml
php7.0-mysql
php7.3-cli
php7.3-opcache
php7.4-opcache
php7.0-fpm
openafs-client
php7.2-readline
php7.0-opcache
php
php-pear
php7.4-json
php7.4-xml
php7.3-json
php7.3-readline
php-bz2
php7.3
php7.3-bz2
libapache2-mod-php
php-xml
Asked
Active
Viewed 1.2k times
Try running
sudo apt-get -f install
sudo dpkg --configure -a
If this doesn't help, you have some problems with your repositories, than you'll need to remove broken repositories from /etc/apt/sources.list and /etc/apt/sources.list.d/
Taras Khalymon
- 246
