Now I can't run Banshee, because of Banshee automatically quit after some time. Question: Where is located banshee configs? Can i delete them to reset settings???
Asked
Active
Viewed 680 times
Rather than deleting all your banshee settings (and database) you can just clear your plugin settings by running
cp -R ~/.config/banshee-1 ~/.config/banshee-1-backup
rm -rf ~/.config/banshee-1/addin-db-*
That also creates a backup... Just in case.
Oli
- 299,380
Banshee config files are in /home/yourname/.config/banshee-1. You can remove this folder to sre-enable default banshee config, but it will suppress your library, you will have to re-scan your disk once you launch Banshee.
winniemiel05
- 259
~/.config/banshee-1/addin-db-001/config.xml
in the config.xml, edit the line with clutterflow in it to say 'false'.
I fixed the issue myself by just uninstalling clutterflow from Synaptic Package Manager, but I think editing the xml is probably a more elegant solution. I only just discovered the xml file now while trying to find a setting for the internet radio buffer.
