Whenever I sudo apt-get update I get an error. Here are the errors from the log:
  Err:13 http://ppa.launchpad.net/ehoover/compholio/ubuntu eoan Release
  404  Not Found [IP: 91.189.95.83 80]
  Err:14
  http://ppa.launchpad.net/gnome-terminator/ppa/ubuntu eoan Release
 Err:15
  http://ppa.launchpad.net/pipelight/stable/ubuntu eoan Release
  E: The repository 'http://ppa.launchpad.net/ehoover/compholio/ubuntu
  eoan Release' does not have a Release file.
  N: Updating from such a repository can't be done securely, and is
  therefore disabled by default.
  N: See apt-secure(8) manpage for repository creation and user
  configuration details.
  E: The repository 'http://ppa.launchpad.net/gnome-terminator/ppa/ubuntu
  E: The repository
  'http://ppa.launchpad.net/pipelight/stable/ubuntu eoan Release' does
  done securely, and is therefore disabled by default.
  N: See
  apt-secure(8) manpage for repository creation and user configuration
  details.
also when I try for example sudo add-apt-repository ppa:openrazer/daily or adding any other repository, I get a similar error
Can someone help me solve this? there are some answers over the internet, but I'm a beginner, so I can't understand how to fix my specific problem and not similar problems... thanks in advance!
Welcome to Ask Ubuntu!
You have a bunch of Personal Package Archives in your installation which are invalid/no longer valid. You'll have to remove the PPA for each error thrown by apt. You can do this as follows:
For
 Err:13 http://ppa.launchpad.net/ehoover/compholio/ubuntu eoan Release 404  Not Found [IP: 91.189.95.83 80]
the PPA name is ehoover/compholio. You'll have to remove this PPA. This can be achieved in two ways.
Method 1
To remove PPA's you need to install ppa-purge (or see Method 2, if you don't want to install any additional packages).
$ sudo apt-get install ppa-purge
You can remove this PPA by running the command
$ sudo ppa-purge ppa:ehoover/compholio
Likewise, run the command for each error line encountered. A complete list for your case would be
sudo ppa-purge ppa:gnome-terminator/ppa
sudo ppa-purge ppa:pipelight/stable
Method 2
You can also achieve this by using the in-built add-apt-repository command. This is similar to method 1.
sudo add-apt-repository -r ppa:ehoover/compholio
sudo add-apt-repository -r ppa:gnome-terminator/ppa
sudo add-apt-repository -r ppa:pipelight/stable
AFAIK these PPA's don't have resources for 19.10, so you'll have to wait. (I may be wrong)
