How can I increase swap partition size?
I would like to shrink the size of partition #5(/dev/nvme0n1p5 which is a ZFS partition) by 6Gb and add it to partition #3(/dev/nvme0n1p3).
I'm running Xubuntu 19.10 with ZFS as root.
Notes:
- Since none of the GUI Partition managers(GParted/Gnome Disks/KDE Partition Manager) currently support changing/moving ZFS partitions, I can't use them.
- I don't want to create another new swap partition on ZFS, I just want to use the current one and increase its size.
- I don't want to create a new swapfile on ZFS!
System Info
sudo parted -l
Model: WDC PC SN520 SDAPNUW-512G-1002 (nvme)
Disk /dev/nvme0n1: 512GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 538MB 537MB fat32 EFI System Partition boot, esp
2 538MB 590MB 52.4MB ext4
3 590MB 2738MB 2147MB linux-swap(v1)
4 2738MB 4885MB 2147MB zfs
5 4885MB 512GB 507GB zfs
sudo fdisk -l /dev/nvme0n1
Disk /dev/nvme0n1: 476.96 GiB, 512110190592 bytes, 1000215216 sectors
Disk model: WDC PC SN520 SDAPNUW-512G-1002
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 9E99ED37-A328-4F95-B9F9-946E5ED049B8
Device Start End Sectors Size Type
/dev/nvme0n1p1 2048 1050623 1048576 512M EFI System
/dev/nvme0n1p2 1050624 1153023 102400 50M Linux filesystem
/dev/nvme0n1p3 1153024 5347327 4194304 2G Linux swap
/dev/nvme0n1p4 5347328 9541631 4194304 2G Solaris boot
/dev/nvme0n1p5 9541632 1000215182 990673551 472.4G Solaris root
sudo zpool list -v
NAME SIZE ALLOC FREE CKPOINT EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT
bpool 1.88G 131M 1.75G - - 0% 6% 1.00x ONLINE -
nvme0n1p4 1.88G 131M 1.75G - - 0% 6.82% - ONLINE
rpool 472G 112G 360G - - 9% 23% 1.00x ONLINE -
nvme0n1p5 472G 112G 360G - - 9% 23.8% - ONLINE
sudo swapon --show --output all
NAME TYPE SIZE USED PRIO UUID LABEL
/dev/nvme0n1p3 partition 2G 7.8M -2 52702bf2-1e50-4ece-8d3e-db01cff707fe
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 19.10
Release: 19.10
Codename: eoan
